Any how-to for replacing Alternator?
Old Apr 29, 2008 | 07:06 PM
VT Mitsu's Avatar
Took the Evo into the dealership...
My Battery and Brake warning lights have been on for a bit.
Turns out the ecu is programmed to flash those 2 bulbs if there is an Alternator/Generator issue! So there ya have it.
The alternator is apparently overcharging the battery according to the tech.
I have not found a how-to on this site and am going to post a request for one, or see if anyone has tried this in the past.
Tom
Old May 10, 2008 | 01:35 PM
4TUN8's Avatar
Man it's deep in there....You're probably going to do it from under the car.
Old May 10, 2008 | 02:58 PM
RevMoto's Avatar
it is pretty simple. Goes on the same way it comes off. It is not adjustable also. Take off the belt. Should be 2 bolts I believe and then put the belt back on.
Old May 11, 2008 | 02:34 PM
VT Mitsu's Avatar
thanks for the replies, gentlemen.
Old May 13, 2008 | 01:46 PM
k2boarder3187's Avatar
there is a how to...i looked at it a while ago i think its more of a problem getting the actual alternator out of the engine bay then removing it from its bracket
Old May 16, 2008 | 05:27 AM
JakeTheVIII's Avatar
I've done it 3 times, it doesn't look to good from the bottom with the axle right in your face. From the top is how i've always done it. I think I saw a mistubishi how-to online that wants you to remove about 50 parts to get it out the top. I took off the FPR and moved a few lines on the left side of the engine bay and was able to pry it out. It sucks.
Old Jun 1, 2008 | 11:31 PM
shangai's Avatar
any pictures?
armysoldier1073
Evo X How Tos / Installations
Jan 23, 2012 10:36 AM
terror75
21
May 25, 2011 10:15 PM
sakorynt
Mar 3, 2011 10:19 AM
dragmod
Jan 28, 2008 04:11 PM
Box Rocket
Jan 1, 2007 09:14 AM
