Tranny and Tcase carnage
The ACD at a stop is open just like a non lsd front diff. It will let which ever end has less traction to take off real fast and once the ACD computer sinces it and goes to lock the diff it makes for a very violent deal. So in Aarons case the front was at 20mph and the rear at 10mph and the ACD locked it up like a rock.
I currently run mine in tarmac, and with my damn stock suspension and RT-615's (whoever here said they have good traction off the line, did you buy yours on a Wednesday?
) I know it's spinning the front off the line and not the back... almost ready to put on the coilovers, poly diff mount, and maybe a set of drag radials... be nice to know what the best is, lock it completely, ebrake it, or maybe the "snow" mode??
Hello, I have a lot of t-case parts here (except for ring and pinions) so if your case and front diff are hosed in your t-case, I can fix that if interested. It would be a lot less than buying a new one and I will also tighten things up in there and upgrade the case bolts.
Your tranny really doesn't look bad at all. I would be willing to bet that the internal parts are still in good shape and you just need the case, which I also have. New that case end is only $248.90. I would just rebuild and beef up the parts you have now as they don't look to be totalled to me. If you want to sell them, give me a call at 719-243-5305 as I would be interested in them for cores here
Thanks for the plug WickedE!
Jack
Jack
Jack
Jack
-E
Hmm, Does 3 clicks even engage the ebrake, or have a negative side effect to a run? What would be the best way to defeat the ACD just for launch purposes or maybe a switch to disable for going to the track? I really dont mind launching with the ebrake and integrating it's use into my launch as it also aid's preloading. Is this the method that would be best? Or would it be advisable to figure out how to disable ACD for a launch.
Lucas, the reason I ask is because we blew a Tcase just like this, on Ottomatic's MR with around ~350tq and a twin plate, destroyed the hollow shaft and center diff.
https://www.evolutionm.net/forums/sh...hlight=carnage
https://www.evolutionm.net/forums/sh...d.php?t=294422
Donald was running open DP when the incident happened and I always wondered if DP collision may have played a part in the broken case or if it was just gear spreading.
Here is a picture of the EvoM member ottomatic 's down pipe. Notice no clearance. He's got a bolt loose too. edit* I've already told him it needs to be fixed immediatly.
Here is a smaller downpipe with clearance on my car.
