i have an odd boost leak anyone with ideas please?
Old May 5, 2008 | 08:35 PM
Liqquid's Avatar
Originally Posted by IAmADirtDude
give me an idea of how to improve that post you gave me. thats a great How To post! all i know is that i did the tear down (since im getting the parts tomarrow), and im pissed now! lol i was pulling off my upper ic pipe (buschur) and it hit the sensor where the line hooks from the bottom of the intake to the sensor....PISSED now i have another part to order and i pulled it out and tore it apart and it looks like a 100$ part it looks like some sort of valve and i broke the plastic tab off that the line hooks to. SUX!
Old May 6, 2008 | 11:26 PM
IAmADirtDude's Avatar
here's an update.... DONT BREAK THE VACUUM SOLENIOD!!!! its normally under the stock air box but the buschur upper ic pipe goes right next to it and its EASY to break 125$ for nothing! dont break it
Old May 7, 2008 | 06:21 AM
AlwaysinBoost's Avatar
did you actually leak test your car or are you just pulling stuff off and replacing it?
Old May 7, 2008 | 06:38 AM
cheb evo's Avatar
+1...really hope you marked the TPS (throttle position sensor) with several marks to make sure it lines up correctly when you put everything back together. I also marked the spring on the throttle body with a mean streak marker to make sure the spring matched up to its original position. If you did not mark the tps, you are going to have some driveability issues
Old May 7, 2008 | 10:08 AM
marked and made sure i knew how much spring wrap it had before i pulled it apart.....and definatly leak tested.
when i pulled it apart it was apparent the leak was coming from the spring side seal. loked like maybe the car sat on a dirt lot in inventory forever cuz the rubber was just weathered and cracked all of the way around the edge.
tried to save myself the drive and the messing around at the dealer and the gas didnt work out lol instead it cost me 155 total between the vavle and the works seals
4dooradam
Jun 21, 2016 06:29 AM
neodestroyer
59
Apr 9, 2009 09:42 PM
IAmADirtDude
21
Jun 12, 2008 04:21 AM
Jon91TSi
Jul 19, 2007 05:17 PM
ShtrMcGavin
Jun 21, 2006 10:48 AM
