Will a 3" cat-back fit on the stock cat?
Old Aug 10, 2003 | 01:28 PM
nine4surfah's Avatar
Im planning on purchasing a 3" cat-back system soon and this question just dawned on me. If the stock exhaust system is 2.5" inches, will changing to a 3" inch cat-back back cause fitting problems on a stock 2.5" cat?
thanks ran
Old Aug 10, 2003 | 01:45 PM
Option2's Avatar
It will fit just fine.
Old Aug 10, 2003 | 02:03 PM
YellwTyper's Avatar
?? Are you sure about that. 3", and 2.5" where do you suppose that will work. Is the exhuast full 3" across, is it street legal, what is OD of the Cat? I think if it is street legal, it will. They usually come with a tapered end so that it will fit smaller fittings.
Old Aug 10, 2003 | 06:14 PM
jfh's Avatar
jfh
I ran the Vishnu 3" catback with factory cat prior to installing 3" DP and hi-flo cat. Cat-back is not tapered but there is just enough surfance area where the 2.5" factory cat flange joins the 3" cat-back flange to allow them to seal.
Old Aug 10, 2003 | 08:51 PM
evo8usa's Avatar
The AMS Cat Back has a collector that is 2.5" at one end and 3" at the other. Every thing comes together just fine.
Old Aug 12, 2003 | 07:25 PM
cdavy's Avatar
Registered User
I have the 3' RMR DP and Cat back and it's fine with the stock cat.
Old Aug 13, 2003 | 01:23 AM
thanks to all those who replied!!!
-ran
Old Aug 15, 2003 | 03:05 PM
David Buschur's Avatar
Our exhaust, the SCCA legal version, is designed to fit to the stock cat also. It uses a bellmouthed piece that necks down to 2.5 inches. This piece can be removed later and you can add our 3" downpipe or offroad pipe to the system. The nice thing about this is you don't end up with a 2.5" restriction in the middle of your full 3" exhaust system.
David Buschur
www.buschurracing.com
robban87
Apr 4, 2017 05:40 AM
Evo_Rex
Sep 7, 2011 08:40 AM
jesterEVO
12
Apr 3, 2006 01:52 PM
Z1 Performance
10
Aug 27, 2005 06:01 PM
evo_will
May 4, 2005 07:11 PM
