ACT XTSS vs HDG6 6 Puck
Old May 12, 2008 | 01:32 PM
caLi4G63's Avatar
I currently have an ACT 6 puck with a HD pressure plate. I love the combo and wouldn't mind getting it again for the money. For daily driving it's not bad at all, yes there is some clutch chatter but that's expected with performance clutches. As stated above by another user, driving up hill in slow traffic BLOWS big time, you'll hate it. As for performance, I've put multiple launches on this clutch and it's held up great with no signs of giving up. I would recommend this clutch to those who don't mind a little bit of chatter and don't have a problem with clutches that are "grabby". Considering the OP has had experience with ACT clutches, I think this will be a great clutch.
I also want to add I wouldn't recommend the XT pressure plate. The clamp force is past the 3000lb mark which makes it much harsher on our transmissions. I believe it was Shep from Shepard Racing who said he didn't recommend any clutch with a clamp force of over 2900lb clamp force - don't quote me on this.
Old May 12, 2008 | 01:36 PM
Turbo Kyle's Avatar
Lots of good info flowing in guys....I did alot of searching before I posted!
Thanks!
Old May 12, 2008 | 01:56 PM
4DR's Avatar
4DR
I have the HDG6 (sprung puck). the first few hundred miles were touchy...hard to get used to because right as it engages...it grabs hard. I love this clutch and got a great deal on it. I have 15,000+ miles on it and 30+ launches. .....not much, but I love it.
Stock flywheel btw.
Old May 12, 2008 | 02:13 PM
RevMoto's Avatar
I have no problems with my clutch. I am running the Hd sprung 6 puck. The XT from my understanding is horrible on high rpm shifts. That is the reason why I stayed away from it. I also think it is overkill. Stick with the hd pp and add the sprung 6 puck disc.
Old May 12, 2008 | 02:18 PM
wshihdnevo's Avatar
^exactly
Old May 12, 2008 | 02:29 PM
Jorda420's Avatar
I got a HD with a 6 puck unsprung disc 20k on it. sux in trafic and a little hard to brake in but worth the money
Old May 12, 2008 | 02:34 PM
Turbo Kyle's Avatar
Cool, I have the HD PP now...I was thinking of just getting the flywheel resurfaced and hitting the PP with a light abrasive wheel like this>
and just throwing in the 6 puck disk (125$) and testing my luck, insted of spending 500$ for the whole darn thing. ACT said the puck clutch diggs into the flywheel and PP more....what ya guys think?
Old May 12, 2008 | 03:03 PM
Evoluvin's Avatar
yeah i also got the stock flywheel resurfaced on my 6 puck
Old May 12, 2008 | 03:46 PM
evoPirate's Avatar
sweet! I was just about to search the HDG6 as I'm 95% sure thats the clutch I'm going with. Nice to see this comparison lol Now to hit up Gruppe-s......
Old May 12, 2008 | 06:24 PM
RevMoto's Avatar
I have never used those but it is hard to say on what you can use till it is actually off. I would say get a sander and run a 40 to 60 grit on it and see how that comes out
Old May 12, 2008 | 09:22 PM
Turbo Kyle's Avatar
Sounds good, Im just going to use a few diffrent methods to get the surface clean. I guess I will be the EvoM gini pig and see how long this 6 puck clutch will last reusing the HD PP.
Old May 13, 2008 | 12:00 AM
RevMoto's Avatar
you will be fine. As long as you didn't run the pp to its death by slipping the clutch when it was going I am sure it is repairable. Just don't make it too smooth.
Old May 13, 2008 | 08:25 AM
Turbo Kyle's Avatar
Cool, I can still drive it on gated 13psi of boost....its not all the way out. It just wont hold power.
Old May 13, 2008 | 01:03 PM
RevMoto's Avatar
ok, I drove around like that for a month. It will definitely get a lot worse so change it out as soon as possible
Old May 13, 2008 | 03:15 PM
Turbo Kyle's Avatar
Right on, I parked it today and broke out my trusty Toyota. Made an appointment to get the clutch put in on the 26th. I figure if I took it easy on the clutch for a week it might help to remove glazing on the PP anf Flywheel. Its parked for now
