resistance on egt probe?
Old May 12, 2008 | 06:23 PM
mitsubishifreak's Avatar
do you guys know what the resistance in ohms should be on a cold greddy egt sensor?60 deg f any other way to test for probe failure?what is the output voltage or mv or resistance it should be when warm or at full idle warm?thanks
Old May 12, 2008 | 06:30 PM
Import Junky's Avatar
well thermocouples are gonna give you a mV or millivolt output and of course an RTD will vary in resistance. I'll see if I can find a chart for you. It should probably be a "K" type thermocouple.
Old May 12, 2008 | 06:32 PM
roughly 619 mV should be the output @ 60f this is only an estimate. I found a chart for output using Celsius so I had to find a conversion table for F to C then cross reference the output for C
Old May 12, 2008 | 06:34 PM
on second thought it might be a "J" I'll dig further
Old May 12, 2008 | 06:44 PM
as far as i can tell looks like k type.yes probally right for mv and not volts.assume resistance will change as gets warmer so was trying to get base idea.i can convert to c if you have tha also thanks for the help junky
i agree with you on the nike comment how true.
Old May 12, 2008 | 06:51 PM
Well as far as color goes in the U.S. "J" is red/white and "K" is red/yellow with both reds being the negative. I got Megan Racing EGT and it was red/white but not "J" over seas they have a different color code than we do. I should know because I work in an Instrument shop. I'm not totally clear on what else you're looking for though. Do you need a link to what I found? Maybe that'll help you out.
Go here and scroll down to find what you're looking for.
http://www.temperatures.com/tctables.html
supwiddiss
Aug 17, 2015 10:27 AM
4cdndctn
Apr 20, 2008 02:53 PM
BADEVO
13
Dec 26, 2005 07:30 PM
EvilBlueEvo8
Jul 14, 2005 07:21 PM
Claudius
Feb 28, 2002 01:01 PM
