Twin-scroll skeptics...
Old Mar 24, 2010 | 11:13 PM
  #166
spdracerut's Avatar
Originally Posted by 03whitegsr
CART/IRL, Lemans, WRC, TurboF1 all seem to have used single scroll setups at their pinnacle. Many WRC teams were using twin scroll setups until Garrett produced the TR30, which is a single scroll turbo similar in size to a GT30. The TR30 was also used in IRL and Lemans. I believe it has been replaced with a next generation of turbo though, but it's still a single scroll arrangement.
A little nitpick but IRL never used turbos. Cart, which became Champ Car, used the Cosworth 2.65L with Garrett turbos. And the current Indycars use NA engines.
Keep in mind that a circuit racing application is different than a street car app. There are not too many circuits with extremely slow corners; the cars are generally able to stay up in the RPM range where the benefits of twin-scroll design is limited.
In WRC, they use anti-lag, so lag is not an issue
In Lemans, Peugeot uses a V12 and Audi a V10. So they have 6 and 5 cylinders feeding each turbo respectively. With the V12, you could do a pair of twin-scroll turbos, not so much on the V10. But with racing, everything comes down to weight. Those TR30Rs only weigh like 8 lbs or something ridiculous. With their transmissions, they're able to stay up in the rev range quite easily negating a lot of the benefits of twin-scroll.
Also, in racing, the simplier the better. And weight, rather the lack of, is key. So the benefits of twin-scroll don't make much sense on a modern race car.
For a street car? Twin-scroll makes all the difference in the world. The list of twin-scroll turbo cars is only getting bigger (new BMW N55 3.0L engine, 4.4L V8 in X5M/X6M, next gen M5, Evos, JDM STis, GM Ecotec engines, Mini Cooper S, etc.)
Another example of something that makes a huge difference on a street car, but not used so much on race cars: variable valve timing. Why? Because the purpose of it is to make a fatter powerband. But a race car should always be in the upper revs. So variable valve timing just adds extra complexity (something to break) and more weight.
Old Mar 25, 2010 | 12:39 AM
  #167
johno's Avatar
I like what you said about the variable valve timing. Personally im not a fan of it i like keeping it simple. You are also very right on the wrc comment anti lag i was thinking about trying it out but just seems so hard on the turbo. I have a friend building a hta3582 pretty sure its twin scroll. i want to see how it goes. very interesting thread though and those f1 motors are something of beauty
Old Mar 25, 2010 | 08:33 AM
  #168
03whitegsr's Avatar
Ok, I was mistaken on some fronts.
That's pretty much what I was getting at. Street cars there is no doubt a benefit for powerband.
Drag cars, I'd still agree there is a benefit. A GT42 for example barely spools by 7000 RPM in an undivided housing on a 2.0L. Toss it in a good TS setup and it's at full sing by 5500 RPM. A lot of the street class cars have weight limits that are easily reached so you can make up for the weight of the TS setup by pulling it out of other areas.
In my particular setup though, I'm more interested in a limited HP range that still allows a fairly small turbo. I'd prefer to have a bare minimum of weight though and a simple engine setup. The rev range for power that I care about is 5K+ so the difference in response is going to be much less.
I think people are taking my argument as an argument against TS in typical applications. It's not and I'm only arguing for a paticular setup and not a general case.
Old Mar 25, 2010 | 08:47 AM
  #169
Ted B's Avatar
Ah, the golden age of CART and its big, manifold mounted pop-off valves. Cosworth DFXs, Chevy Ilmors, Porsche, Alfa, etc., all running at 21psi and those gutsy, gritty stock block Buick V6s running 27psi and sounding like hell on wheels. I remember ...
There's nothing like learning something new.
Yep. There is a benefit in any application where a 4-cyl engine is fitted with a relatively large turbo, especially if rpm drops below that required to deliver full boost pressure anywhere on the course (or street).
Old Mar 25, 2010 | 09:38 AM
  #170
hokiruu's Avatar
03 whitegsr, it really sounds like everything you want is in a stock-frame turbo with a good lightweight tubular manifold. Besides that, I don't understand what your debate is here.
Old Mar 25, 2010 | 10:10 PM
  #171
03whitegsr's Avatar
The debate is just that I could get a GT30 based setup with tial housing for 1/2 the weight of a stock frame turbo. But reality, it's only 10 pounds difference, before the weight of the wastegate on the GT30 setup. The GT30 may be slightly less expensive as well.
Old Mar 25, 2010 | 10:30 PM
  #172
scorke's Avatar
With a .82 can you deal with losing that much tq on the top end for all your down low responsiveness? The 30R is a good turbo but it's easily over worked on a 2.3 with boost,on a 2.0 as well but it's not as drastic because its not as high at the beginning. You lose 200+ ftlbs of tq, I'llprefer a car that makes peak tq from 4k-8k, not 3k-6k.
Thats a 2.3 30Rcar with mild cams at 30 psi on C16...
To me, you go with the stock frame TWIN SCROLL FP RED or Green, call it a day for simplicities sake and accept it or go bigger with a T4 frame manifold and setupso you can do your 450 whp and make tq to redline on less boost, and make 1100whp so you choose later if thats what you want to do.
If you are really attached to the Tial hotside do it, the v-bands are nice.
Scorke
Old Mar 26, 2010 | 01:47 PM
  #173
jid2's Avatar
The precision .63 AR housing is the one to use for a GT30R in T3 open scroll, it's the only one worth looking at. These new T3 twin scroll are interesting though, and the T4 twin scroll on a 35R ish is pretty proven now. Geoff seems to know this stuff better than anyone else and has invested the time to try lots of things.
For reference to that plot posted above, I have mine from last week posted below. Very similar but with a Precision .63AR turbine housing. 2.3L, GT3076R, 28 psi, E85. I make less peak torque, which is expected at 2 less psi of boost, but mine doesn't fall off as much, I drop 100 ft-lbs; ignore the cliff at the end that is the dyno reading after lifting at 7300 RPM. I peak at 450 ft-lbs, and make 350 ft-lbs out the top. And this is with a smaller AR. AMS tested all the turbine housings back in the day and picked the Precision .63 AR because it spooled faster AND made more top end than the garret .63, or garret .82.
V-band is really nice though. It makes life easy, and you don't worry about all your bolts falling out, which is a classic issue for turbine to manifold, and turbine to O2 housing. Twin Scroll V-band is the next new hawtness.
Old Mar 26, 2010 | 02:52 PM
  #174
scorke's Avatar
Sorry JID but yours falls off just as much as mine does. I would expect if you ran it out to 8500 and kept it wide open the hp and tq graphs would still look the same, the 30R just runs out of breath at this power.It would be more apparent that yours was declining as much as mine was if it was running as much boost.
Peak boost=Peak TQ in this situation, the rest of the variables on my motor were very stock. You can clearly see that my peak comes earlier than yours, and the pull was started later, indicating that it was probably spooling quicker in my scenario.
Regardless of this I am making more tq than you before peak boost would come into play, and at similar RPM indicating that the .82 seems to work better, considering I gave up very little which would be expected, especially with a 2.3.
The Precision .63 is the housing that AMS pretty much exclusively uses, all the other vendors seem to stick to the .82, precision, or the new tial stuff now.I'm just lost as to how you can say the .63 is the one to use with a 30R given our two graphs. Your curve seems to peak later, but with the housing it should happen sooner, no?
Scorke
Old Mar 26, 2010 | 03:45 PM
  #175
jid2's Avatar
I looked closer, you are right about the torque out the top, at 7000 RPM they are about the same, and I stop the pull earlier so it's hard to tell after that.
What gear is your pull in? Mine is 3rd.
I think the shift in peak torque is just the timing in the tune. E85 is a little picky at peak torque, and I didn't want to push to the limit, so I run low timing in the area where you are at peak - most likely. My car hits full boost at 4200 rpm in 3rd.
They are pretty close then, it's lame to compare dyno sheets anyway, I should refrain from the urge...
But this is way off topic. Twin Scroll V-band For The Future Win, FTFW.
Old Mar 26, 2010 | 06:38 PM
  #176
scorke's Avatar
My run's were in third. Fullboost at that RPMS sounds about right for the gear if we are talking race gas boost levels.
Hahah agreed on lame about comparing dyno sheets, but it's nice to see how close they are, 3k miles, and 3 years apart! To think of it now I've been through 2 sets of cams, 2 intercoolers, two turbo setups, and 2 rotating assemblies since then
Scorke
Old Mar 26, 2010 | 07:19 PM
  #177
EvoDan2004's Avatar
TS VB???? really. any pics or info. sizes and such
Old Mar 26, 2010 | 08:27 PM
  #178
jid2's Avatar
^^^ I don't think it exists, but when it does it will pwn all, and be declared king 03whitegsr and I have crazy garage fantasies about building one from scratch though
Old Mar 26, 2010 | 08:28 PM
  #179
EvoDan2004's Avatar
yea it would be interesting to see. i can build one with some lego's but i dont think it will hold up. maybe ill send it to myth busters.
Old Mar 26, 2010 | 09:04 PM
  #180
ScorpionT's Avatar
Will you build one to match my lego manifold? I used JB weld, it should do just fine.
