Ikeya Formula Sequential Shifter
Old May 18, 2008 | 02:07 PM
RalliartMR's Avatar
i was wondering how would this work or be installed. It says that it mounts onto your shifter..but i dont get how reverse would work??
heres the link
http://www.bulletproofautomotive.com...il.php?ID=1870
Old May 18, 2008 | 02:12 PM
SpunEvoIX's Avatar
heres the link
u see the product but dont read the details....
The Ikeya Formula Sequential Shifter will allow you to shift in a forward/back pattern, although you will still need to use the clutch. No more missed shifts! This piece mounts onto your shifter and has a lever to allow you to engage reverse gear. The stalk is tall and the knob is close to the steering wheel.
Old May 18, 2008 | 02:20 PM
RalliartMR's Avatar
i know that.. what i wanna know i does but does it engage it the same way..all the way to right and down
Old May 18, 2008 | 02:22 PM
SpunEvoIX's Avatar
its either shift all the way up and pull the lever or all the way back
Old May 18, 2008 | 02:25 PM
BluEVOIX's Avatar
I guess you use the lever that is the small peice in the picture. And its probably a forward back motion not side to side.
Old May 18, 2008 | 02:27 PM
staatz's Avatar
only 1200...
Old May 18, 2008 | 02:31 PM
SpunEvoIX's Avatar
Originally Posted by staatz
only 1200...
yeah about the same u use in gas a week nowadays
Old May 18, 2008 | 02:35 PM
RalliartMR's Avatar
+1
Old May 18, 2008 | 05:50 PM
mymigi's Avatar
there is a small lever that you depress and push the main lever forward to engage reverse. the cool thing about it is, let's say you're in fourth gear or maybe even fifth and have to come to a stop, you can just push the lever down and after your last gear it will go back to neutral, pretty neat but a bit awkward for daily driving.
Old May 19, 2008 | 12:01 AM
chuntington101's Avatar
norris design run one on his SWB 9. looks a pretty impresive bit of kit. i have heard negative things from the prosche gusy thopugh. they recon you can change faster with a normal H patern....
Chris.
Blue_Lion
May 24, 2017 06:25 PM
TWM Performance
Feb 28, 2017 07:36 AM
THE4TH
13
Dec 29, 2015 07:58 AM
Mirage2.0
Lancer Tranny/Drivetrain Tech
32
Jan 18, 2007 03:15 PM
crnesst
13
Nov 29, 2004 06:58 PM
