Climate Control
Old Aug 12, 2003 | 11:27 AM
mayhem's Avatar
Climate Control
The climate control dial on my Evolution seems to stick and bind sometimes. But once I move it from max heat to max cold it's back to normal. A day later, same thing. It even has a lot of slack in it. You have to turn pretty far before it feels like something is engaging then once it does it feels like it's binding..weird.
Is anybody elses doing this or just mine?
Old Aug 12, 2003 | 11:53 AM
leonard_shelby's Avatar
no, mine works fine.
Old Aug 12, 2003 | 12:01 PM
!!!!!!!!!!!!!0Z's Avatar
In Timeout
Werd. Try KY Jelly. Wurx4me!
Old Aug 12, 2003 | 12:13 PM
SilverEvo8owner's Avatar
look right above the gas pedal, to the right, and behind the dash. Whenever you turn the dials there are plastic pieces that move. Try seeing if the is a wire or somehting that it tangled. You should see the same type of thing on the passenger side too.
Old Aug 12, 2003 | 12:40 PM
this is it
Old Aug 12, 2003 | 12:46 PM
zyounker's Avatar
Yeah mine binds.. mine if i turn it to feet and upper, then turn it on it will pop to upper only..
I think it is just a crappy design...
Old Aug 12, 2003 | 05:52 PM
emulous's Avatar
My temperature selector guage does the exact same thing, I agree ****ty design.
Old Aug 14, 2003 | 09:43 AM
erioshi's Avatar
Mine seems to have stopped going completely to vent. When I switch to cold the cable seems to stop moving the flap about at about 1/4 heat. Unfortunately that means I NEED to run the AC on 70 degree or warmer days - otherwise the vents will cook me.
Anyone else seen this?
Old Sep 22, 2003 | 11:23 AM
WINSTON's Avatar
Registered User
My car did the same thing, took to dealership and they fixed it.
Cheers,
winston.
kinglasserres
Jul 28, 2025 10:34 AM
AWDb00st239
Dec 23, 2014 09:20 PM
evolutionated
May 15, 2012 06:08 AM
Stealthmatt
Mar 15, 2010 07:07 AM
Slo_crx1
Mar 22, 2009 09:04 AM
