Basic Trans Rebuild?
Old May 24, 2008 | 03:24 PM
Freddy302's Avatar
My Trans is out and I want to replace the syncro's whiles it out. I'm in the Northeast and wanted to know what parts I should order and who I should get them from.
Thanks,
Freddy
Old May 24, 2008 | 03:41 PM
gsrboi80's Avatar
Just send it to Dog Box in NJ
Old May 24, 2008 | 03:50 PM
Freddy302's Avatar
thx for the reply.. I want to replace the syncro's myself. Just didnt know the best place to get parts at a good price and semi local to speed the process up.
Old May 24, 2008 | 04:09 PM
gsrboi80's Avatar
Oh no doubt sorry misunderstood. Just order new ones from mitsu thats what all the builders use anyway
Old May 24, 2008 | 04:57 PM
4kinboost's Avatar
Pm me. I'll see what discount you can get through Toplevel.
Old May 24, 2008 | 05:26 PM
Paul Nelson's Avatar
Get them thru the dealer they can have them in a day or might have them in stock. Tell them your with a shop and you want a discount
Old May 24, 2008 | 05:55 PM
Freddy302's Avatar
Thanks For the replies guys.. I Let you know what ends up working for me.. thx
Old May 24, 2008 | 06:05 PM
Juan MR's Avatar
can the synchros be ordered or do u have to order the entire gear set say a 4th gear
Old May 24, 2008 | 09:06 PM
dsmfan95's Avatar
You can order the synchros separately. I got the 5th/reverse synchro, so I can fix the 5th gear grind problem.
Old May 27, 2008 | 05:47 PM
Freddy302's Avatar
Hey Do these parts seem right? I just didnt know how many of each as well.. thx
Quantity Part # Description
MD748058 Ring+m.t Synch
MR581382 Ring+m.t Synch
MD770348 Ring Assy+m.t 3rd
MN168934 Ring Assy+m.t Rev
MR581385 Ring Assy+m.t 2nd
Old May 28, 2008 | 07:03 AM
highhats's Avatar
Send it to jackstransmissions.com on an exchange basis
Suman
Old May 28, 2008 | 05:16 PM
Freddy302's Avatar
Thx Suman! I will def take a look into that option.. Looks like a killer trans at a very fair price.
Old May 28, 2008 | 06:00 PM
Mitsutech56's Avatar
1-2 Synchronizer Sleeve MD749220 qty 1 <--- Only needed if the points are rounded
1st gear synchro & 2nd gear synchro MD770748 qty 2
1st gear synchro spring & 2nd gear synchro spring MD748670 qty 2
For 2nd- to-3rd gear shift grinding noise, use the following new, improved parts:
3-4 Synchronizer Sleeve MR581388 qty 1
3rd Synchronizer Ring MD770348 qty 1
3rd Synchronizer Spring & 4th Synchronizer Spring MR581389 qty 2
For 4th- to-5th gear shift grinding noise, use the following new, improved parts:
5-Rev Synchronizer Sleeve MN168859 qty 1
5th Synchronizer Ring MR581382 qty 1
5th Synchronizer Spring & Reverse Synchronizer Spring MR581383 qty 2
Reverse Synchronizer Ring MN168934 qty 1
Factory Liquid gasket MD997740 qty 1 <---- the only stuff I use
The 3,4,5 & Rev parts are from TSB-04-22-003REV
Parts listed in this bulletin must be used together. Do not install new parts with earlier parts.
PM me if you have any questions.
Old May 28, 2008 | 06:07 PM
jmelocik's Avatar
Great info! What years does that TSB apply to? If I am grinding going from 4th to 5th will the dealer replace or rebuild it under warranty? Thanks again.
Josh
Old May 28, 2008 | 07:03 PM
jmartinez1170's Avatar
just buy it from TRE and do it yourself
Freddy302
May 29, 2014 09:53 PM
Freddy302
Aug 6, 2013 06:30 AM
mgrgata
Feb 5, 2012 07:25 PM
STWHY?
Sep 29, 2010 01:38 PM
Freddy302
Jan 31, 2007 04:55 PM
