Miata battery?
Old Jan 12, 2012 | 06:13 PM
  #31
silverevo05's Avatar
actually height of the honda and stock are the same
Old Jan 13, 2012 | 07:50 AM
  #32
3bar_dc2's Avatar
I was talking about the height of the honda compared to the miata. Sorry I should have made that clearer. I'm not sure if it's the same or taller than the Miata or not.
Old Jan 13, 2012 | 08:20 AM
  #33
kimma's Avatar
anybody have more pics of this miata battery installed with short route piping..iam about to get one..i currently have a ets but wondering if this battery would indeed fit with a cut/modified oem battery tray
Old Jan 13, 2012 | 09:06 AM
  #34
3bar_dc2's Avatar
My post up there which is post #25 shows a Muse (Buschur replica) short route pipe with a Miata battery installed with a cut OEM battery tray. Just made my own tie down.
Old Jan 13, 2012 | 09:14 AM
  #35
bhmax's Avatar
Originally Posted by bhmax
Can the AGM (gel) batteries be mounted on their sides without issues? Was thinking of the Miata one listed and putting it in the spare wheel well.
Figured it isn't any issue, but Westco confirmed you can mount agm any position. Should mount laying on its side where the spare goes if you are comfortable just going with tire repair items. I'll be looking into that more. Would prefer to have the rest of the trunk free. Prev owner had a wire running for a sub that I don't need.
Old Jan 15, 2012 | 07:25 PM
  #36
vmrevo9's Avatar
Veteran: Air Force
what year Miata are you guys using? im interested in doing this with my stock battery tray.
orielly's has a battery that is similar to the optima line. apparently they have had a bunch of optimas returned for warranty while their brand battery has been doing good... so they say lol
thanks in advance!
Old Jan 15, 2012 | 08:34 PM
  #37
3bar_dc2's Avatar
thanks in advance!
If I remember correctly there's only 1 Miata battery. If not, I think I used a late 90s when looking up.
Old Jan 15, 2012 | 08:39 PM
  #38
vmrevo9's Avatar
Veteran: Air Force
cool thats what i figured but wasnt sure!
thanks for the info
Old Jan 23, 2012 | 11:06 PM
  #39
autozone is the westco with the waarranty
Old Jan 24, 2012 | 02:38 PM
  #40
h22gordo's Avatar
I've been using Miata batteries for the past 5 years with great results.
I'm on my 2nd one in 5 years.
Works great with my XS Engineering intercooler piping.
Old Jan 24, 2012 | 02:58 PM
  #41
talonkev's Avatar
Here is another thread on this topic: https://www.evolutionm.net/forums/ev...a-battery.html
I also have an album in my profile that has pictures of the modified stock tray I made years ago.
Old Jan 24, 2012 | 04:01 PM
  #42
^ Hey TalonKev thanks for the info before.
H22gordo My only concern on the miata battery is the recharge durability that I have been reading about.
These AGM miata battery have to be trickle charged and used at least once a week right? otherwise they damage or die
How often do you guys use your car with the Miata battery?
Old Jan 24, 2012 | 04:32 PM
  #43
talonkev's Avatar
My original Westco battery died when it was a few months old. I needed one right away so I went to Napa and got one that day. Westco sent me a new replacement battery within a week, so I now have 2 batteries. They are both over 2 years old now. My Evo is driven maybe 2-3 times a week during the summer, and doesn't get driven at all in the winter. I normally put the batteries on a tender when not in use. But they both have multiple occurrences of being stored for months not hooked up to the tender without any problems.
Old Feb 19, 2012 | 10:25 AM
  #44
Well I test fitted a honda battery group 51 not 51r and it fit great my only concern is that I had to cut both side supports on the battery tray to make it fit and I fear that it will slide forward to back upon acceleration and decel.
I guess I will have to go miata. What is the lowest cca our cars need?
Old Feb 19, 2012 | 12:19 PM
  #45
kikiturbo's Avatar
I have an optima running in that position...
It is about 1/2 of an inch higher than boot floor, so the original cardboard doesn't sit right... but otherwise it is OK... Great battery, especially for people that do not run the car regularly...
