Pistons????what to RUN
ok like the title says im in a big
on what to get for compresion and which kind!!!!
my block is 20over so need some suggestions Thanks
i know speedclinic has the cps i guess there a new design
chris@nolimit ive ordered alote from him he had told me resently he has wisco pretty cheap!!!
on what to get for compresion and which kind!!!!my block is 20over so need some suggestions Thanks
The block is already 20 over and have you checked the block to make sure you can do a drop in.
If you plan on running big power over 600whp get ross not the std. the racing pistons with the coating and all.
Anything under 600whp wiscos will do.
bc springs/retainers
stock valves for now
looking for 500ish with reliable safe tune and then later on when i see there can be more on the table ill try to see what the 35 will hold but with me not baller status ima keep it safe for now
lmk
he was going to run them with his 42r setup
ross pistons huh ill ask some vendors on here and see what there all about or do a search
i was going to pick up some wiscos from a guy that said there the best and will hold 375hp in each cylinder so i was thinking about those..
AMS uses ross pistons on there motor builds so that will tell you something right there.
Wiscos on a 42R unless there the HD pistons i wouldnt use them past 600whp thats just me.
josephcastelar
Mar 28, 2013 12:42 PM
