TS requires duals
Old May 29, 2008 | 10:13 PM
Ted B's Avatar
I don't know. It's something that we can't seem to effectively measure.
Old May 29, 2008 | 10:35 PM
RevMoto's Avatar
I will make a couple different extensions then and log each one.
Old May 30, 2008 | 04:54 AM
DTM's Avatar
DTM
Originally Posted by RevMoto
DTM uses a DNP manifold. The twin gates allow for quicker spool. This is the point of a twin scroll and also gives more consistent flow to the wastegate. Don't quote me on that though. Hopefully some of our fabricators will come chime in on this.
This is incorrect. We do not incorporate a DNP manifold in our kits. ONE customer brought a manifold by for us to build him a kit utilizing the DNP T4 TS manifold they produce. With that said, we mentioned in that thread that we were impressed with the construction and flow characteristics of the manifold. It worked very well and incorporated only ONE gate. We build our own manifolds that also incorporate One gate. We haven't found any quicker response from utilizing one or two forms of gate.
What we have found however is that some setups require two gates for better boost control and space for proper gate entry and exhaust.
Old May 30, 2008 | 04:20 PM
RevMoto's Avatar
The first kit you guys put together did, for testing.
Old May 31, 2008 | 05:37 AM
sparky's Avatar
When "true" twinscroll design is mentioned, does that mean that on an inline four cylinder engine, the manifold has no common collector and that there are two divorced, pairs of runners turbine housing exclusively, while the remaining two runners feed exhaust gases into the other half of the housing?
Old May 31, 2008 | 08:34 AM
Ted B's Avatar
Yes, exactly.
asubennett
Feb 27, 2011 04:13 PM
balleronabudget
24
Jan 23, 2011 12:08 PM
BlackonBlack2
Nov 6, 2008 04:07 PM
gunnerman
Apr 13, 2006 11:06 PM
gunnerman
Mar 2, 2006 12:10 PM
