264 cams in an evo 8
Old May 30, 2008 | 04:34 AM
grillpt's Avatar
I have HKS 264/264 and I love them. I don't know what power I made before the cams but afterwards I made 297whp & 310wtq at CBRD with Chad tuning the car. Keep in mind he has one of the lowest reading Dyno's on this forum. Stock VIII's make 190-200 whp on his dyno.
I have the exact same mods as you minus the LICP. If you want great mid-range power and torque with near stock idle, get the 264's. I love the way my car pulls now...
Old May 30, 2008 | 09:26 AM
laxhero2's Avatar
i have 264 i got them cause of my daily drive spools fast and still has a decent top end
Old May 30, 2008 | 09:33 AM
fugiwara's Avatar
who said hks 272 cams are lopey? back then it is lopey, but now with the ecuflash and experience of the tuners, they are just very mild cams. I had my HKS 272 installed recently and they idle almost like stock. it all depends on how good your tuner is to smooth out the idle.
Just don't waste your money on HKS 264, or 264/272 combo.
On average cam will give you 20-30 hp gain, depending on cams and your supporting mods.
Old May 30, 2008 | 09:58 AM
justchil's Avatar
HKS 272's or GSC S1's FTW
I have 264's and wish I would have went bigger now that I have the fp green.
Old May 30, 2008 | 10:17 AM
lexat20's Avatar
264s are a waste of time and $$$ imo. HKS 272's are great for the stock turbo and even up to a 35r. Your tuner shoudl be able to adjust for the idle.
Old May 30, 2008 | 10:20 AM
Billy@EnglishRacing's Avatar
go bigger then a 264, you will be disappointed in the end
Old May 30, 2008 | 11:13 AM
SmokinU's Avatar
I love my 272/264 split.....never thought they were lopey compared to stock even. It really all depends on the tune.
Old May 30, 2008 | 11:15 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by EVO8emUp
Part of the reason why I don't want 272s is because of the lopey idle. I also heard you sometimes get a CEL because the ECU thinks its misfiring. Not that the CEL bothers me. I'd just like to keep it as stock appearing as possible. I'll probably end up doing cams at the same time as the 2.3L rotating assembly, it would only make sense.
I just built one for a friend's GVR4 and so far it seems to be holding up well. I did it for free (he just paid for the parts) so I could see what exactly I was getting into.
As for you throwing a CEL it's not going to happen. I'm running 272's on stock turbo with reflash and my idle lopes a little bit for about 1 sec. And as for power I made 355whp on c16. A buddy of mine who lives in Philli did his own flash on the same dyno I sent to the only difference with his setup compaired to mine he has GSC S1's and a Perrin FMIC and turboback exhaust. I have HKS 272's and stock FMIC, turbo back exhaust, LICP. I think with just the difference with cams and FMIC he made 390 on c16
Old May 30, 2008 | 02:44 PM
STikiller.com's Avatar
Thanks for the GSC cam suggestions everyone.
The S1s will provide very nice spoolup and midrange. Top end is improved, not as much as the S2, but you loose some spool/midrange power on S2s.
It sounds like you want some nice power, but with a smooth idle and long power band. I would definitely suggest the S1.
You can turn the boost up alittle bit more, to around 24-25, and make some very nice power!
With Mivec, you can adjust it to idle like stock, or lope like it has 300s in there.
Thanks,
Travis
Old May 30, 2008 | 08:47 PM
YearOne's Avatar
Just FYI...I am running HKS 272s with DTM head and I put down 325whp at 23psi/ 93 octane on DTM dyno when it was 76 degree in the shop.
Originally Posted by jmelocik
I am currently running HKS 264I/272E in my 05 VIII with stock turbo and ECU with mods in my sig. I made 308 AWHP (Mustang Dyno, approx 345 on DynoJet?) at DTM in Virginia. I am getting ready to sell my 264/272 setup to a member on here and then I am thinking straight 272's. I already have some HKS 272's but now am thinking else! Some one buy my 100mm crank so I can get some head work done! LOL Thanks
Josh
Old May 30, 2008 | 09:07 PM
SpooksEvo's Avatar
do a little research on the forums. Someone compared the ones you are talking about and the GSC S1's were superior in gains. I gained 50whp with mine
Old May 30, 2008 | 09:15 PM
04AWDTURBOEVO's Avatar
264i/272e HKS Cams on my set-up.
Good for a solid 405 whp still at 7,800 rpms on the little 20GLT.
Old May 30, 2008 | 09:25 PM
taenaive's Avatar
I am running 260/272 combo also. good street set up.
380 dllHP with stock evo 8 turbo.
However, I want to try 280s .
Old May 11, 2012 | 12:34 AM
vtec fever's Avatar
what numbers did u make with this setup?
Old May 11, 2012 | 02:30 AM
el.guerrero's Avatar
suggest to go with gsc s1, greg say what to do to make our baby go!
Gsc s1 has newer design and make more power and nicer powerband!
talonkev
Jun 7, 2017 05:18 AM
LancerShop.com
Sep 16, 2016 06:08 PM
nodnarb416
11
Jun 11, 2011 05:51 PM
Santiago@AMS
Automotosports - Illinois
Mar 24, 2007 06:41 PM
Wangracing
May 10, 2006 09:47 PM
