stock boost psi?
I dont understand what you are saying about the boost taper. You want "like 22 all the way" ? Where did you come up with that number? I have an 8 with the 10.5 hotside, and I have been running 25 psi, tapering down to 20, for well over 100,000 miles on a stock block. So, no, it is not necessary. Do I WANT head studs? Sure do. -s
9.5 psi boost on my stock Evo IX?
Installed HKS EVC-S on my Evo.
It was showing 9.5 psi boost (on factory setting), don’t know why.
Now I have set it to 15 psi, and its performing great now.
Doesn’t perform well beyond 16 psi, I was wondering what might be the issue.
Current Boost-Controller Settings :
Offset : 60%
Response : 20%
Drop : 5%
Warning : 10.5 psi
Over-Boost : 17 psi
Offset : 60%
Response : 20%
Drop : 5%
Warning : 10.5 psi
Over-Boost : 17 psi
