Need Help, Oxygen sensor.
Old Jun 8, 2008 | 09:14 PM
smoke777x's Avatar
Hey guys, My car recently threw the po171 and po134 code witch means that car is running lean and there is no activity from my O2 sensor in bank one. I understand that those two codes come together sinse the ecu is not getting any voltage from the sensor so its going to throw the lean code, but is it possible that its actually not the O2 sensor that is bad on my car? My car is pretty much stock just a TBE, Lower pipe, ported mani and a flash from previous owner. Also, are the sensors same from the 03 and 06, or are they interchangable? Thanks.
P.S, my car is running pig rich, which im reading from my wideband.
Old Jun 9, 2008 | 04:52 AM
dryad001's Avatar
Its your 02. The same thing happened to me a few weeks ago. If your not getting any voltage from your 02 then why would it be something else? Go to sparkplugs.com for the best deal.
Old Jun 9, 2008 | 05:32 AM
smoke777x's Avatar
I didnt check if it was getting any voltage, cause i dont know how to. Im just guessing that. How would i check that?
Old Jun 9, 2008 | 06:17 PM
smoke777x's Avatar
Well... does anyone know if the O2 sensor changed in the 06 evo from the 03-05? Because i don't want to buy a sensor and it doesn't even fit my car. Someone please help, I think i read almost every thread on this but nothing that explains that.
Old Jun 9, 2008 | 07:49 PM
Jay644's Avatar
I would first reset the ecu and see if the code comes back. If it does then check the sensor itself. Make sure all the wiring is good and the connectors are nice and tight. It could be a lot of different things.
Check this link out it might help.
As for buying a new sensor just select the year and model of your car and get the primary o2 sensor since its saying that its in Bank 1 and cause is throwing off your AFR's.
Good luck.
Old Jun 11, 2008 | 05:51 AM
smoke777x's Avatar
The problem is that no website carries the O2 sensor for an 06 they all only have the sensors from the 03 to the 05. Does any one know if they are the same because i need one asap.
Old Jun 11, 2008 | 08:07 AM
smoke777x's Avatar
bump
Old Jun 11, 2008 | 12:22 PM
smoke777x's Avatar
Well, I just called mitsubishi and spoke to the parts department, and they told me that the oxygen sensors are different and that they would have to actually know if im in Cali or somewhere else because there is a difference also. Just tought i would let everyone know in case someone wanted to know.
Old Jun 16, 2008 | 11:48 AM
hytek369's Avatar
is the evo 9 o2 sensor the same as the evo 8? i am referring to the one in the cat.
Old Jun 16, 2008 | 11:50 AM
hytek369's Avatar
they only sell sparkplugs, no o2 sensor.
Old Jun 16, 2008 | 12:50 PM
mplspilot's Avatar
If you have a Zeitronix wideband, or any WB with narrowband output, you won't need to buy a new O2 sensor. You can just wire that output to your ECU.
Old Jun 16, 2008 | 01:22 PM
Zeitronix's Avatar
Stock NB O2 sensor is easy to test.
Cali or not, the narrowband O2 sensor voltage oscillates roughly between 0V and 1V. Connect a voltmeter to the O2 signal give the O2 couple minutes to warm up and go for a drive. AFR richer than 14.7 should give you about 1V leaner than 14.7 about 0V. Just like here:
http://www.zeitronix.com/questions/O2questions.htm
Old Jun 16, 2008 | 05:09 PM
hytek369's Avatar
is there any difference between the front o2 sensor and rear? not sure why the rear costs more.
Old Jun 17, 2008 | 01:00 PM
hytek369's Avatar
any updates?
Old Jun 26, 2008 | 07:16 PM
bzzbee2's Avatar
maybe its just a longer wiring harness
