Tcase removal
Old Jun 20, 2008 | 07:00 AM
insanechief's Avatar
mmm i dont know about the oil pan? im thinking that may damage or dent it right?
Old Jun 20, 2008 | 09:29 AM
justboosted02's Avatar
no you wont, just put a piece of wood between the jack and the oil pan. you are not lifting the engine by it, you are simply pushing the engine forward a bit.
this is how ive done it in the past
Old Jun 20, 2008 | 10:51 AM
cool thanks!
Old Jul 28, 2008 | 02:44 PM
Originally Posted by justboosted02
+1
you do not need to drop the subframe, remove the rear engine mount and put a jack on the oil pan to swing the engine forward.
Is this the rear mount i need to remove and hold up the engine under the oil pan? I did remove the Tcase but it sucked it more than likely beable to be installed without moving the engine.
Old Jul 28, 2008 | 03:15 PM
Anyone. There like 3 or 4 other mounts in and around the engine but this one is attached to the tranny. So im not sure and i dont want to remove this one and the damne thing is even harder.
Old Jul 28, 2008 | 03:16 PM
ak47po's Avatar
Follow this.
http://evomoto.com/tech_info.php?tPa...ac81ee8e896997
Old Jul 28, 2008 | 03:23 PM
Yes, i did but all they do is pull it to the side and do not remove it.
Old Jul 28, 2008 | 05:53 PM
yea, remove the bolt going though that mount and the engine will be able to be pushed forward quite far, just make sure you dont puncture your rad!
Old Jul 28, 2008 | 05:58 PM
Cool thanks, will i need to support the trans or on the engine oil pan i dont want to damage anything.
Old Jul 28, 2008 | 06:40 PM
no, the engine will still be supported by the motor mount by the cams and the motor mount on top of the transmission
Old Jul 28, 2008 | 06:47 PM
Thanks justboosted02!!!!!
corndog17
Lancer Engine Tech
20
Dec 22, 2020 08:53 PM
steven121
Feb 9, 2014 07:13 PM
thebluesky
14
Jul 9, 2013 06:49 PM
thebluesky
Mar 28, 2006 05:12 AM
agent5568
Lancer Engine Tech
113
Dec 4, 2005 12:44 AM
