Tcase removal
Old Jun 18, 2008 | 06:15 AM
insanechief's Avatar
Tcase removal
Ok im knee deep into it and the post i read said to remove the support under the car that runs front to back with 3 bolts 2 front and one rear. but the motor mount is attached to this. Will the motor be ok if i remove this or do i have to support it with a cherry picker or something similar?
Old Jun 18, 2008 | 09:33 AM
ok i figured that out. no big deal.
does the cross member from left to right need to be removed? It does not state that on any posts or the evo repair manual, but it doesnt seem to want to come out.
Old Jun 18, 2008 | 09:36 AM
PATRICK B.'s Avatar
If you're leaving the trans on and the driv/pass mounts.
You may have to loosen or unbolt the rear mount to tilt the motor&trans together far enough to squeeze the tc out.
I can't remember exactly but i think i may have loosened up the entire lower member to drop down about an inch or so to also help getting the tc out.
Hope that helps some.
Old Jun 18, 2008 | 09:42 AM
yes im leaving the trans in. im just replacing the seals in the tcase. so i can just lower the cossmemebr a few inches?
Old Jun 18, 2008 | 09:43 AM
Also dont i have to disconnect from the rear drive shaft?
Old Jun 18, 2008 | 09:52 AM
PATRICK B.'s Avatar
Need to disconnect the d/s at the first yolk 4-12mm nuts.
Then slide it out and then i normally remove the tailshaft housing 4-12mm bolts i believe.....just be careful.
I don't think i had to lower the cross member much...... not more than 2 inches if i remember correctly.
Sorry but this last time i left the t/c in while i swapped clutches so it's been a few months lol.
Old Jun 18, 2008 | 09:58 AM
EvoHung's Avatar
unbolt the rear mount and put a jack with a block of wood under the front of the engine, jack up the engine to give you room to pull off the tc.
Old Jun 19, 2008 | 10:24 AM
So remove the rear engine mount (the one attached to the crossmemeber)? How is the Tcase attached to the D/S?
What is the best way to lower the the crossmemeber?
Weird the EVOmoto "How to" mentions nothing about lowering or removing crossmember.
Old Jun 19, 2008 | 02:19 PM
PATRICK B.'s Avatar
Like i said you may not necessarily have to lower the crossmember as i was r&ring the entire motor/trans together when i did mine. I removed the t/c prior to dropping the entire assembly.
Sorry to come off like a a-hole but are you serious about the d/s question? Did you read my other reply above
The rear mount is held in place by 2-17mm bolts and has a long bolt that goes through the rubber.
Old Jun 19, 2008 | 05:02 PM
Yes that came out wrong ill be back at it this weekend.
Old Jun 19, 2008 | 05:08 PM
EvoHung's Avatar
Once you get down there, it should be pretty obvious as of what and how things are connected.
Old Jun 19, 2008 | 05:33 PM
yes i pretty have it out it just doesnt want to come from behind the crossmember. i am just looking for tips on it.
Old Jun 19, 2008 | 09:15 PM
EvoHung's Avatar
Jack up the front of the engine, this should give you more room to wiggle it out. Wait, I think its the back of the engine...one of those. I can't remember, it's been a while.
Old Jun 20, 2008 | 05:45 AM
I guess the front would give me a lil more room. Thanks
Old Jun 20, 2008 | 06:16 AM
justboosted02's Avatar
+1
you do not need to drop the subframe, remove the rear engine mount and put a jack on the oil pan to swing the engine forward.
