Indy Intake V2 done and tested.
Old Jun 18, 2008 | 11:50 AM
gsrboi80's Avatar
WOW that Indy manifold has a fat midrange in comparison to the DI and didnt lose much past that. Impressive results indeed
Old Jun 18, 2008 | 11:59 AM
9sec9's Avatar
It GAINED in the top end. Compare the graphs very closely. Look at the curve closely. The Indy manifold doesn't do anything up or down, it's just very smooth in its power increases. I think that from 7500 up, they'll be close, but the ported stocker is still going to be on top. The change in whp at 6700-6800 shows that the stocker is continuing with it's normal curve. The DI shows a dip at that same point, possibly leveling off. Most drag racers are always above 6500, so the power could be a factor.
Old Jun 18, 2008 | 12:02 PM
evovin's Avatar
Nice !!! I want one
Originally Posted by Mellon
who would have thought a ported stock mani could hang with the sheet metal intakes...nice job guys.
I thought its cast plus sheet metal on this design? (please correct me if im wrong)
I wish we could see a picture.lol
Old Jun 18, 2008 | 12:12 PM
ImprezvSE's Avatar
Originally Posted by Driven Innovations
All of Daves dynos are always to 7.5-8k. Would my manifold make more power at 9k+? Yes, I have no doubt about it. What everyone needs to understand is that this Stock modified manifold, its a great upgrade for people that want stock appearing manifold.
Thats a big assumption, and you have no proof to back it up. I'm not knocking your product, I like it a lot. However before the Indy manifold existed I'm sure you had " no doubt" that no stock ported manifold could hang with yours. Today we know different and I'm just looking for more info above the 7,500 rpm range. Again thanks to Dave for his time testing these two great products.
Old Jun 18, 2008 | 12:23 PM
Driven Innovations's Avatar
I never claimed that stock ported couldnt hang with sheet metal manifolds! This V2 manifold makes more power than most sheet metal manifolds. I'm very happy that Indy made this intake and that Dave did all of the testing! I think it show how well my manifold performs for the cost!
Old Jun 18, 2008 | 12:31 PM
ImprezvSE's Avatar
Again I like your product just looking for more test info above 7500rpm.
Old Jun 18, 2008 | 12:34 PM
EvoDan2004's Avatar
i also would like to see from 7k to 9k.
Old Jun 18, 2008 | 12:53 PM
Lonnie@LMS's Avatar
Very interested in higher rpm testing as well. Great job Indy and thanks Dave!!
Old Jun 18, 2008 | 12:58 PM
Aby@MIL.SPEC's Avatar
AWESOME WORK INDY 2 corona's for you!
was the oem intake ever tsted with a 65mm tb in the previous "SUPER" intake mani test? i forget.
if so, could david please post up the most (if possible ) comparison data of the v2, oem & di intake mani's?
Old Jun 18, 2008 | 12:59 PM
crcain's Avatar
Pretty amazing stuff.
I haven't looked at a stock manifold in a while but... could the inlet of the manifold be ported to 3" for a 3" throttle body?
Old Jun 18, 2008 | 01:12 PM
9sec9's Avatar
I'm not sure, but another comparison could be the DI and V2, BOTH with 65mm TB. This test shows the DI w/3" and the V2 w/65mm.
Old Jun 18, 2008 | 01:24 PM
whooshski's Avatar
Thanks for the testing.
Old Jun 18, 2008 | 01:35 PM
ImprezvSE's Avatar
Originally Posted by davidbuschur
The car made 650 whp at 35 psi today in 3rd gear.
Tomorrow morning the Indy Intake goes back on and then back on the dyno. I am hoping for great things.
I have one problem. I didn't know I was out of race gas and I forgot to order it today. I have enough fuel in the car for maybe one or two runs
Someone emptied the drum and didn't say anything.........................
Not sure if it was the slipping tires or clutch but yesterday you said the car made 650whp and today you said the car made 632whp both with the DI manifold. Were these numbers at different RPM's just curious as to why the DI was down on 18whp today from yesterday when the boost was the same. Thanks
Old Jun 18, 2008 | 01:37 PM
steelcityevo8's Avatar
Wow great product Indy , this is a tribute to your dedication and engineering skills
And again to David Buschur for being the highly dedicated person he is. Without Dave the Evo community would have so much less info availible to make proper decisions
Old Jun 18, 2008 | 01:38 PM
9sec9's Avatar
634 today. 637 was the Indy V2.
