O2 housing sensor question (had to cut wires, wire question)
Old Jun 20, 2008 | 11:38 PM
hytek369's Avatar
any one used a bosch universal o2 sensor as a replacement? can you tell me wiring color scheme? mitsu has 2 blacks, 1 blue and 1 white. bosch has 2 whites, 1 black, 1 grey.
Old Jun 21, 2008 | 05:37 AM
EVO8emUp's Avatar
If you solder it correctly, you should be fine. Its all in how you twist the wires together and apply the solder. Don't forget to slide the heat shrink onto the wire first.
Old Jun 21, 2008 | 12:31 PM
hytek369's Avatar
which color goes to which?
Old Jun 21, 2008 | 10:33 PM
Jeff_Jeske's Avatar
Make a post in the wanted section for a front O2 sensor. You can get a nearly new one for $80 shipped. I run alot of leaded fuel and have two spares "just in case".
Old Aug 26, 2008 | 07:06 PM
Craig King's Avatar
Where can you buy new O2 sensors with the correct plugs for our cars?
Old Aug 26, 2008 | 07:25 PM
hytek369's Avatar
dealership
kamote2000
Mar 8, 2017 12:30 AM
Mitsu3
Feb 17, 2007 05:52 AM
mostro
Jan 27, 2007 03:55 PM
deekay247
Dec 15, 2004 12:01 AM
GTVEVO
May 26, 2004 01:11 PM
