Quartermaster Twin Disc from Devo Tuning
Old Jun 21, 2008 | 06:59 AM
1slowevo's Avatar
Originally Posted by burnok
this clutch does own all.
Originally Posted by slicedbreadno2
So this has stock pedal feel?
due to the hydraulic throw-out bearing, it has a similar feel to stock, much lighter feel than an exedy or act
Originally Posted by crcain
I've only ever run Exedy clutches... have recently ordered a kit to rebuild my twin to a triple. But I'm curious what are the benefits of the Quartermaster?
lighter mass ( I believe 17lbs total with flywheel) easy recovery on bogged launches, less strain on drivetrain
hydraulic throw-out bearing (lighter clutch pedal)
changes clutch to pushtype, no more clips falling out
Will it allow you to slip the clutch easier on a launch?
yes
Does it shift better? I never had problems shifting an Exedy but maybe this one is that little bit smoother?
it shifter butter smooth and ultra fast with no lock outs
How much torque is it rated to hold?
I have seen this clutch on a few 8 and 9 sec evo's and talons (I assume they make 500-650tq)
How would an Exedy Triple metal clutch compare to this do you think?
Quartermaster > Exedy Triple metal
I can't understand the OP stalling so much. Is this clutch very hard to slip? If so, would that not mean it's hard to slip for a launch?
it is a little hard to get used to at first, once you do, its much easier
its actually very consistant and easy to launch at the track
Anyway I don't mean to be negative about this clutch, I'm just trying to ask some hard questions to get a sense of what to expect if I ever went this route down the road.
answered in bold italics
Old Jun 21, 2008 | 08:59 AM
PATRICK B.'s Avatar
If you read my post closer you'll notice that i say i had a hard time stalling at first because the lessening of weight in the clutch assembly caused the rpm's to rise and fall quicker which necessitated an adjustment to the AEM so all is good now idles like stock and drives very well.
As far as the other answers to your ?'s 1slowevo hit them right on the head
Matter of fact i'm gunna hop in and cruise around some more it's like driving a whole new car again after having the **** poor shifting qualities of the last clutch
Old Jun 21, 2008 | 09:21 AM
crcain's Avatar
Thanks for the answers guys.
I'm not too sure what to think. It just seems odd to me Bushur and AMS don't sell this clutch. I think clutches are very subjective.
1slowevo, have you ever owned an Exedy Twin or Triple and what power were you making?
Old Jun 21, 2008 | 10:37 AM
1slowevo's Avatar
If you look AMS sells a similar setup now, Exedy w/hydraulic TO bearing.
BR I believe runs the Tilton CC, similar setup to the QM as well.
I have had many different clutches, disc, twin, and I have driven both exedy twin and thriple carbon as well. I love the QM more than all the previously mentioned
As for powerwise, the car has gone through serious transformation since the beginning (much like many others on here)
VIII turbo 350hp/380tq
IX turbo 395hp/398tq
BR3065 503hp/460tq
35R built motor 600+hp/520tq (108mph 1/8mile traps)
I have gone through 2 rebuild kits, but that is due to well over 500+ launches on the car
Old Jun 21, 2008 | 12:06 PM
crcain's Avatar
Thanks again for your answers! Did not mean to interrogate you but just wanted to get an idea of the type of experience behind the opinion!
I've ordered the pull -> push conversion along with the rebuild of my exedy twin to triple from AMS. So I'm hoping that having the hydraulic release bearing will help make the Exedy less grabby when trying to slip it.
Old Jun 21, 2008 | 12:13 PM
PATRICK B.'s Avatar
THAT'S WHAT I WANT TO HEAR!
....w/ 108 1/8mi speeds are you running in the low 10 sec range?
Old Jun 21, 2008 | 04:04 PM
1slowevo's Avatar
we will find out next Saturday
Old Jun 21, 2008 | 04:15 PM
red evo8's Avatar
congrats on buying an awesome product, any clutch can be dd it just takes getting used to, I mean doing something the same way for years and then all of a sudden change just takes time.
Old Jun 21, 2008 | 08:25 PM
dafunk630's Avatar
this is goin to be my next clutch.
Should i do the clutch before the tune??? does it matter???
Old Jun 21, 2008 | 10:21 PM
1slowevo's Avatar
as long as the clutch that is in the car is holding, then you should be fine.
you might have to change idle though after installing this clutch due to the light weight of the clutch/flywheel assembly
Old Jun 22, 2008 | 03:48 AM
1NastyMR's Avatar
I own one and Love it drives perfectly fine noise doesn't bother me great clutch for the price
Old Aug 5, 2008 | 01:37 AM
Johnboy1065's Avatar
I've heard that using a hydrolic bearing to convert our clutches to a push type can cause crank walk. any truth to this that ya'll know of???
Old Aug 5, 2008 | 06:24 AM
vboy425's Avatar
you need to weld a stopper bolt under your clutch pedal for this clutch cause it hit the crank thrust bearing pretty hard every time you pressing the clutch pedal down.
Old Aug 5, 2008 | 06:34 AM
xiaoni420's Avatar
The clutch is simply bad*ss. Definitely has a "race clutch" feel during engagement in 1st gear, but all subsequent shifts can be very smooth once you get used to it. Rev matching is like night and day compared to the stock clutch. Shifting can be done much quicker and at high RPMs. People talk alot about the chatter on this clutch but I have heard alot worse. The clutch peddle pressure feels just like stock, it is extremely light, however the engagement is obviously much harsher like any twin disk will be. I put the clutch in about 3 weeks ago now, and I couldn't be happier.
Old Aug 5, 2008 | 06:37 AM
Zeus's Avatar
Anyone who has had both the Exedy Twin HD and this clutch want to chime in on chatter? I'm curious as to how bad it is. My Exedy is almost chatter free, but I might be interested in something a little more user friendly.
