TTP piston drop in project - amazing!
Old Jun 23, 2008 | 04:19 PM
  #31
k2boarder3187's Avatar
awesome write up!! making me want to do this! lol
Old Jun 23, 2008 | 04:21 PM
  #32
Originally Posted by razorlab
What's wrong with this photo...
Old Jun 23, 2008 | 04:23 PM
  #33
topturtle's Avatar
Very nice writeup. You have me thinking about upgrading the rods and pistons now.
Old Jun 23, 2008 | 04:50 PM
  #34
DTM's Avatar
DTM
Curious about your post : "you will see the beautiful crosshatch later" I don't see it. Nor what you did to ensure the cleanliness of the bore and the rest of the block. What are your piston to wall clearances, rod bearing clearances and how your mains looked?
The pics of your stock pistons look like they had a huge problem with heat and high carbon build up. the tune looked to be a bit rich and non efficient.
Not to burst your bubble, but what your showing and think and what some of us are seeing are two completely different things.
My two cents.
Old Jun 23, 2008 | 05:36 PM
  #35
TTP Engineering's Avatar
The mains would not need to be removed, nor would the main girdle. The mains would never be removed from the car.
Old Jun 23, 2008 | 05:40 PM
  #36
DTM's Avatar
DTM
I understand that. They wouldn't even be able to come out to be checked with the way that he has left the block and trans in the car, My concern was with the look of the bores on the first few picks. IMHO I just would have et least dropped the engine and looked everything over. Piece of mind that is all.
My other questions are still valid and deserve a response by the original poster.
  #37
DTM's Avatar
DTM
BTW the pistons look great!! Good job on them
Old Jun 23, 2008 | 06:47 PM
  #38
justboosted02's Avatar
My two cents.
i was thinking the same thing
Old Jun 23, 2008 | 07:26 PM
  #39
1badgsex's Avatar
god i want the ttp je spec pistons soooo bad iam in the middle of doing a buschur stage 3 short block right now and i want the ttp spec je pistons in my motor but all well, buschur motors come with "special spec" je pistons also but not like the new ttp ones.. god they are so bad *** every time i see them its like pouring straight alch on a open wound it hurts !!!!
Old Jun 23, 2008 | 08:00 PM
  #40
its not like you'll be able to see them when the motors all put together. They are sexy tho.
Old Jun 23, 2008 | 10:38 PM
  #41
RanEvo's Avatar
my apology for not getting back to you, I was slipping
anyway, I believe you understand now that I haven't removed the crack, so main bearings are not my concern. as for clearance issues, as the TTP JE pistons are custom to stock size, and my assumption (after compression and leak test before head removal) is that we have healthy engine to start with, the concerned will be only the honing issue, so that's why slight honing was carried to break the glazing only.
I will not argued as to my tuning, but this picture of the valves on the head will say more than I have to explain about the lambda in my tune before the drop in job
Old Jun 23, 2008 | 11:00 PM
  #42
cfdfireman1's Avatar
I like mine..
..with a little less oil on the walls. ?
Old Jun 23, 2008 | 11:05 PM
  #43
CO_VR4's Avatar
Originally Posted by Sharkbite2000
All the piston's are in the down position ?
Just out of curiosity, can you explain how all the pistons could be "down" at the same time with the crank in the block?
Old Jun 23, 2008 | 11:08 PM
  #44
evovin's Avatar
Old Jun 23, 2008 | 11:43 PM
  #45
riceball777's Avatar
nice write up? did you file the pictons rings for the proper clearances? check piston to wall clearances and check rod bearing clearances???
