Steady boost (tru boost)
Old Jun 25, 2008 | 09:05 PM
Nevonate's Avatar
First and foremost, my Evo has very few mods. One of the first things I swapped was the Stock boost controller to an AEM tru-boost. I am having a hell of a time keeping steady boost. with spring rate @5.7 and A setting @ 55% I see 21 psi at around 4k , then it tapers off to somewhere around 16-17 psi at 7k. I installed it correctly, I am pulling the boost reference off of the nipple by the compressor housing.
I've tried adjusting the Spring rate to 13 and it seems to help some. Has anyone had problems like this? any advice?
-Nate
Old Jun 26, 2008 | 08:51 AM
Nevonate's Avatar
Anyone???
Old Jun 26, 2008 | 08:55 AM
staatz's Avatar
Just go to a MBC, much easier.
Old Jun 26, 2008 | 03:47 PM
andrewzaragoza's Avatar
if your looking to reduce the taper you should go with the gm 3port boost solenoid and have the ecu tuned to control the boost. you could also try getting a different ebc. you need an ebc that can control the taper. i know the hks or the turbosmart ebc has these feature. don't know about the other brands.
Old Jun 28, 2008 | 09:54 PM
Maxdelta's Avatar
I am working with 55% and 11.5 atm, 67% at 11 was to much and I was spiking 22-24 psi. Ill post results in about an hour
Old Jun 28, 2008 | 11:02 PM
Nevonate's Avatar
I'm not looking for new boost controller solutions, I need a solution with my current Truboost setup. I keep reading about pills, I don't remember removing any pill, should I have?
Old Jun 28, 2008 | 11:04 PM
Boost3dxEvO's Avatar
the "pills" that people are referring to come off of the stock vacuum lines.. did you retain the stock vacuum lines ? or did you go with the ones found in the Tru Boost?
Old Jun 28, 2008 | 11:08 PM
Nevonate's Avatar
I kept the stock vacuum lines.
Old Jun 29, 2008 | 07:51 AM
Nevonate's Avatar
Bump.
Old Jul 9, 2008 | 01:57 PM
SRT-TO-EVO's Avatar
That's your problem these have pills in them. Remove them and use the ones that come with the AEM. Mine runs perfectly, spiking to about 24.8, falling to 22-23.
Old Jul 9, 2008 | 02:01 PM
XSivPSI's Avatar
One of the stock lines has a restrictor (pill) in it. That is your problem
06EvoIX
Jun 20, 2010 10:46 PM
06EvoIX
Apr 12, 2010 02:46 PM
MionieEvo
Sep 21, 2008 09:21 PM
MionieEvo
Jul 31, 2008 03:13 PM
DrEvo
36
Sep 15, 2004 06:23 PM
