Aps Bov Help!! Asap!!
Old Jun 30, 2008 | 11:48 AM
Lancerguy'03's Avatar
just got my APS Bov in....and lookin at it....how far can i screw that top screw in? as much as i need or is there too much?
and side note: if anyone else can give me a ballpark tightness on the BOV for 30psi that would be helpfull..
Old Jun 30, 2008 | 12:12 PM
Evo Tengoku's Avatar
For 30psi, I'd tighten all the way. When I had the APS, I liked it best tightened all the way (was running 25psi)
Old Jun 30, 2008 | 12:15 PM
all the way as in like inside wher is screws? or flush with the top of the BOV? and did u have any issues with flutering?
Old Jun 30, 2008 | 12:27 PM
EVOLex's Avatar
Make yourself a BOV leak tester and adjust it to where it need to be. If I was running a MAX of 25psi I would adjust it to leak @ 27 psi. This way, I know it will fully open when it needs to, and if I happen to overboost it will leak some air. At 30 psi, you might not be able a preload the spring enough to hold, and if you do, you are compromising the travel of the valve. I recommend getting a stiffer spring. By over tightening it, you run the risk of not venting enough.
Old Jun 30, 2008 | 12:46 PM
ROGERV's Avatar
I have mine screwed flush with the top of the nut . (running 28psi)
Also put teflon on the screw so it won't leak.
Old Jun 30, 2008 | 01:05 PM
^^^^^^^^^^^alright. and i did put teflon on the screw....goin to install now.
Old Jun 30, 2008 | 02:32 PM
well install was easy and i think i got it tuned pretty good....i hit 30psi and slowly drops....no flutter at low bost or mid.....but if im at mid boost and let off the thottle slow it flutters some.....but i guess thats life.
also i got pulled over doing some of the tunning.....58mph in a 35mph.....no insurance card...not wearing my glasses.....but its all good....got the Veterans Discount....
Old Jul 3, 2008 | 08:40 AM
got a problem with the BOV and anyone can help..... if i floor it in 5th gear at low revs i got either, BOV leaking or compressor surge.....how do i fix that???
tcarretti
Aug 18, 2011 09:21 PM
Detailguy
Dec 29, 2008 11:53 AM
dubIX
Aug 12, 2006 04:48 PM
IXmr321
29
Feb 8, 2006 01:59 PM
Eveolicious
Oct 18, 2005 05:14 PM
