Redline for HKS 272
Old Jun 30, 2008 | 03:25 PM
Wayne99gsr's Avatar
Redline for HKS 272
I am new to evo scene. don't know much about it yet. my car came with 272 intake/exhaust cams. everything else is stock. wondering if I can rev it up little higher than factory 7K? maybe like 7400 or 7500?
Thanks.
Old Jun 30, 2008 | 03:30 PM
andrewzaragoza's Avatar
the factory valve train could handle up to 8k. anything over that you would need an upgraded valve spring.
Old Jun 30, 2008 | 03:31 PM
Billy@EnglishRacing's Avatar
you are safe up to at least 8
Old Jun 30, 2008 | 03:33 PM
Wayne99gsr's Avatar
8k? damn it.. last time when I went to the track I shifted at 7k every gear. if I knew this sooner I would've got better track time. but good to know.
thanks! guys
still doesn't mean that you are making good power that high
Old Jun 30, 2008 | 06:21 PM
speedy evo's Avatar
i rev it up to 8k all the time with my hks 272.
Old Jun 30, 2008 | 06:27 PM
Vibrant's Avatar
I have HKS 272's in mine as well. I over revved when I missed a gear, and pushed it past 8k. I was ****ting bricks thinking I had broken a spring or something, but my valvetrain proved resilient, and I did not break anything.
(That I know of)
Old Jun 30, 2008 | 07:08 PM
Ph3n1x's Avatar
I think with these cams you will risk breaking an internal component rather than valvetrain since they aren't very high lift cams. 10.8/10.2.
Old Jul 1, 2008 | 12:09 AM
Wayne99gsr's Avatar
thats what Im worrying about..
Old Jul 1, 2008 | 06:02 AM
Ludikraut's Avatar
10.8/10.2 is not considered a high lift cam on an Evo. IIRC, your factory fuel cut is 7600 RPM ... you can bump that up to 7800 RPM if you want. Your shift point on a relatively stock car should probably be between 7200-7500 RPM. I know there are a few people who like to rev the stock valvetrain to 8K and up, but I would not recommend that at all.
l8r)
Old Jul 1, 2008 | 06:37 AM
Soon2BEVO's Avatar
You dont need to rev over 7400 with the stock turbo, but if you upgrade turbos, the stock valvetrain is fine up to 8000rpm with the HKS272s
Old Jul 1, 2008 | 06:59 AM
Gary@MellonRacing's Avatar
if i have a fp green using the 272 hks cam on the evo 8 , im i still making power on top like 8000 8500rpms???
im using springs retainers
Old Jul 1, 2008 | 07:08 AM
Ludikraut's Avatar
You'll make useful power probably up to around 8000 RPM. I doubt an FP Green with those cams will make enough power at 8500 RPM to warrant revving your engine that high.
l8r)
Old Jul 1, 2008 | 08:38 AM
tony gibson's Avatar
I have the evo green at 23 psi and my buddy is running 30psi on an ams 35r set up daily on e85, both cars running hks 272s and we routinely spin up to 8500 rpm in 1st-3rd gear with no ill effects with 80,000 miles on the stock motor...these results may not be typical but take it fwiw
Ferp
Jul 11, 2017 12:12 AM
evolved8 bs
Nov 29, 2015 09:55 PM
l EVO n
26
Mar 25, 2009 12:01 PM
Aby@MIL.SPEC
Sep 6, 2006 01:31 PM
TD05HR
Jan 26, 2005 08:49 PM
