question on mechanical CEL Fix
Old Jan 13, 2009 | 07:45 AM
evane's Avatar
when i installed my 3" downpipe and 3" testpipe i installed a mechanical fix for the rear o2 sensor and it worked for about 3 days and i threw a code and i got tired of clearing the code so i disabled my rear o2 sensor and now i never have to worry about it again
Old Jan 13, 2009 | 09:26 AM
03Evo_8's Avatar
Well then...I guess im gonna take it to the muffler shop to install my dam exhaust for me then...because I was lowering my car yesterday and doing the exhaust then got stuck on the o2 for about 3 hrs....it was just on soo tight due to it being a virgin....
Old Jan 15, 2009 | 01:35 PM
Jamdown's Avatar
I had the ebay SS CEL fix installed but got a CEL after a few days....then it disappeared. I am not certain why but I will get the rear sensor disabled if the HFC I'm getting next month keeps doing the same thing
Old Jan 15, 2009 | 01:46 PM
BluEVOIX's Avatar
I've been running a CEL fix for a very long time now.
It threw a CEL once before after changing my exhaust. I had a big exhaust leak before the o2 which was the cause of it. Once I fixed that leak the CEL went off after a few cycles and never came back on.
So if you guys are still throwing a CEL light with a properly made non fouler, then double check that you dont have any exhaust leaks behind the second o2. (the one that checks for emissions)
Old Jan 15, 2009 | 02:22 PM
ExplosEvo's Avatar
When I did mine, I had a hard time getting the O2 sensor out too. However I just got one of those sockets that made to take out an O2 sensor from the autoparts store and that plus a torque wrench and it twisted right off. Just make sure if you use the CEL fix that you have clearance between the O2 sensor and the body. My original sensor rubbed the body so bad that it eventually broke off. I had to use a hammer and beat a dent into the body so there was clearance.
Old Jan 15, 2009 | 07:37 PM
Jamdown's Avatar
Thanks BluEVOIX....I suspect I may have a leak..the exhaust has a "odd" sound at times, but this being my first exhaust I'm not certain what to expect sound-wise
The hundreds.
Jul 26, 2008 07:39 PM
Protostar1
14
Jul 7, 2008 05:56 PM
supersupra
11
Sep 12, 2006 08:08 PM
TurboIX
Jul 29, 2006 08:15 PM
Dr. SS
Apr 3, 2006 09:49 PM
