Cam timming: one tooth off = how many degrees +/-?
Old Jul 3, 2008 | 05:05 PM
jbfoco's Avatar
Cam timing: one tooth off = how many degrees +/-?
Cam timing:
Thank you!
Old Jul 3, 2008 | 05:11 PM
Ted B's Avatar
Divide 360 by the number of teeth, and you get the number of cam degrees per tooth. IIRC, it's something like 17, which is quite a lot!
Old Jul 3, 2008 | 05:24 PM
Celica2EVO's Avatar
I believe its 7* off the top of my head. but its alot no matter what!
Old Jul 3, 2008 | 05:28 PM
crcain's Avatar
From this pic:
http://www.hksusa.com/images_products/2613.jpg
I count 48... so 360 / 48 = 7.5 cam degrees = 15 crank degress
If you give us the cam specs maybe someone can calculate how much valve lift that might be at a particular crank position?
Old Jul 3, 2008 | 06:38 PM
C6C6CH3vo's Avatar
It is not the fact that they skipped off mark that's bad, it is the direction they skipped with the curent overlap already there from duration and/or mivec.
Retarding (late) exhaust and advancing (early) intake is the bad direction. This means if the belt skipped over both sprockets the exhaust valve has the greatest chance of touching but the intake valve has more clearance. Not sure if one tooth will caust this, depends on duration or even rpm (torsional travel increases with inertia).
If the car still runs without problems after you fix this mess you should be OK.
Old Jul 3, 2008 | 06:43 PM
C6C6CH3vo's Avatar
Or are you asking this as a poor mans adjustable cam gear? If so it's too much
Old Jul 6, 2008 | 01:45 PM
TheLab's Avatar
it is 15 degrees, I know for a fact and have the broken valve and piston to show for it. fyi, when using HKS adj gears use the timing marks at 12 o'clock on the gear, not the marks at 9 and 3 o'clock. If you lined the gears up with the 9 and 3 o'clocl marks straight across horizontally your exh cam will be OK but your int cam will be advanced 2 teeth or 30 degrees which I found with a degree kit. In case youre wondering that is NOT good.
zulu989
Lancer How Tos / Installations
May 7, 2017 06:38 PM
rstchris
AEM EMS
Jan 20, 2016 08:49 PM
doinitevo9style
Jun 27, 2011 03:21 PM
honki24
Dec 20, 2006 09:43 AM
93civEJ1
17
Sep 7, 2004 12:54 PM
