Car trouble, Died while driving
Old Jul 8, 2008 | 12:34 PM
kaonashi's Avatar
i have stock battery, and none of the plugs are sparking, i pulled em out and tried to see if i can get them to spark on the engine and they arent sparking at all. and i know i have compression still i can feel it blowing out of the head when i tried to see if it would spark
Old Jul 8, 2008 | 02:01 PM
kaonashi's Avatar
Where can I order the CAS online?
Old Jul 10, 2008 | 11:32 AM
IEXCELR8's Avatar
Did you try putting your stock coils back in to see if it is the coils.
https://www.evolutionm.net/forums/sh...ighlight=spark
Old Jul 10, 2008 | 02:53 PM
kaonashi's Avatar
no because i replaced the stock one's with these new ones to try to see if they where bad lol
Old Jul 24, 2008 | 10:17 AM
mitsuorder's Avatar
Any luck kaonashi? I get cost plus no tax on oem parts and will do anything I can to help.
Old Jul 24, 2008 | 10:40 AM
MalibuJack's Avatar
do you have a code scanner? turn on the ignition so the ECU is powered up, and read the codes (after cranking it a few times and leaving it in the run position) if you have a fouled up sensor it should show up there which one.
Look for stupid things like one of your intercooler pipes came off or whatnot (assuming it cranks but won't start)
hooliganSKATE
Aug 17, 2015 03:30 PM
hooliganSKATE
Jul 16, 2015 06:21 AM
fullm00nevo
13
Jun 10, 2015 12:07 PM
ziad
Jun 12, 2012 08:22 PM
iwantevonow
Jan 10, 2011 10:43 AM
