A full 37r build top to bottom...COMPLETE!
Ran into a nasty problem last night. I was going to pull the map from the AEM and noticed the fuel pressure only peaked at 4.5psi. I pulled the injectors and 2 of the top o-rings were dry rotted and cracked.
The serpentine belt should be here today, I will throw up some more pictures when its all done.
Hey mike, did you end up going on friday even with the rain on friday?
I ended up blowing up my turbo
so ended up pulling the damn car apart instead. oh well when you go fast you break ****
This quote was taken from the first page.
Yup, never doing another one. This whole build started on July 5th, 2008. Just a little over a year to do it. It was all done on strictly overtime hours alone. Pretty happy with the outcome so far.
I finally got around to start my 6765 build. Engine will be out this week and off to the machine shop. When I get enough time Ill add in the specifics of the build. AC will also be coming out, just need to figure out how to get rid of the freon. Heres a few pics to start off with:
Running extremely rich? Yep.
Overall the cylinder walls are in great shape and even after 50k the cross hatch is still there. Ill see if I cant get a good picture of it.
So far a huge thanks goes out to Mike@AWD, Scott@TTP, Machine Motorsports.
