Bolt On Turbo Line Up
more data points added - interesting comparison between the Green and Evo 9 stock turbo: only ~15hp difference on pump gas. Different for race gas of course; kind of starting to tell a story (e.g. if you only run pump the green may not be very cost effective), but still need more data points ...
Voidhawk, some data for you:
FPGREENS
2006 Evo 9
Mods:
Turbo back 3" exhaust, no cat
GST Open air filter (stock rubber intake pipe)
Denso 720cc injectors
Walbro Fuel Pump
FPGreen turbo (ported hotside)
Ported factory exhaust manifold
Titek tubular 02 housing
ETS 3.5" FMIC
ETS hard Intercooler piping
Sun Hyperforce Ignition
Cosworth Mivec Cams
GM boost solenoid (Ecu-controlled boost)
Upgraded Springs and retainers
91 octane California fuel
23psi peak (1.6 bar), 20 psi (1.4bar) at 7200rpm
11.2 to 10.9 AFR
Stock Ecu with reflash custom tuning
2006 Evo 9
Mods
WORKS 3" turboback exhaust
RRE Rally Cat (test pipe, no cat)
FP Green Turbo w/stock WGA
Ported and coated WORKS O2 housing
Ported and coated turbo hotside and coldside
Ported and coated exhaust manifold
ARP Headstuds
WORKS 62mm throttle body
ETS 3.5" intercooler
ETS LICP
GST Open air filter
720cc Denso injectors
Walbro 255l Fuel pump
GM 3-port boost solenoid (Ecu-controlled boost)
Sun Hyper Force Ignition
Stock cams
91 octane California Fuel
24psi peak (1.66 bar), 20.5 psi (1.42bar) at 7200rpm
11.2 to 10.9 AFR
2006 Evo 9
Mods
Cosworth Mivec cams
FPgreen with IX actuator
Valvetrain upgrade
Headstuds
Fuel Pump
Hard Lower Intercooler piping
3" turbo back exhaust with no cat (HRS catback)
Open Air filter
Hallman Manual Boost controller (bleed valve)
Tubular 02 housing
11.2 to 10.9 AFR
2006 Evo 9
Mods
GSC S1 Mivec cams
FPgreen with FP actuator
Fuel Pump
Nisei upper/lower intercooler pipes
3" Turbo back exhaust with no cat
HKS Kansai airbox with HKS 'flower' filter
HKS hard intake pipe
GM boost solenoid (Ecu controlled boost)
Tubular 02 housing
24psi peak (1.66 bar), 21 psi (1.45 bar) at 7200rpm
11.2 to 10.9 AFR
2006 Evo 9
Mods
Upper and lower hard intercooler pipes
Tubular 02 housing with porting
FPgreen with porting
Stock exhaust manifold with porting
Sun hyper ignition system
Fuel Pump upgrade
Open air filter
GSC mivec cams
GM boost solenoid (ecu controlled boost)
23psi peak (1.6 bar), 21 psi (1.45 bar) at 7200rpm
11.2 to 10.9 AFR
Same Evo, 91 octane California fuel plus methanol injection
25psi (1.75 bar) peak to 23psi (1.6 bar) at 7200 rpm
11.5 AFR
Stock Ecu with reflash custom tuning:
Same Evo, 100 octane fuel plus methanol injection (unfinished tune)
28.5psi (1.97bar) peak to 24.5psi (1.7bar) at 7200 rpm
11.8 AFR
2005 Evo 8
Mods
FPGreen w/ WOT porting
GSC S1's with Cam gears @ -1/-2
65mm WOT Throttle body
Forge RS BOV
RC 750cc injectors
Cold Air Boxâ„¢
Ebay open air filter
PPI exhaust mani (ported)
Works 3" 02 & Downpipe
100 cell metal cat
RNR 3" catback
Nisei FMIC & UICP
AMS lower IC pipe
Swain coatings
GM solenoid (ecu-boost control)
21.5psi peak (1.5 bar), 20 psi (1.4 bar) at 7200rpm
11.2 to 10.9 AFR
Same Evo with 100 octane fuel
24.5psi peak (1.7bar), 24psi (1.65bar) at 7200 rpm
2005 Evo 8
Mods
FPgreen turbo with stock evo 9 actuator
Stock exhaust manifold and stock 02 housing unported
HKS 272/272 cams
HKS cam gears (set at +1/-1)
Walboro fuel pump
ETS FMIC
Nisei LICP
Stock UICP (upgraded with tbolts but stock couplers)
3" catback
2.75" Espelir downpipe
RRE rallycat (no cat)
GST open air filter
GM boost solenoid (ECU boost control)
100 octane Fuel
26.5psi peak (1.83 bar), 23 psi (1.6 bar) at 7200rpm
11.7 to 11.5AFR
FPGREENS
2006 Evo 9
Mods:
Walbro Fuel Pump
ETS 3.5" FMIC
Cosworth Mivec Cams
11.2 to 10.9 AFR
2006 Evo 9
Mods
ARP Headstuds
ETS LICP
GST Open air filter
Stock cams
11.2 to 10.9 AFR
2006 Evo 9
Mods
Cosworth Mivec cams
Valvetrain upgrade
Headstuds
Fuel Pump
Open Air filter
Tubular 02 housing
11.2 to 10.9 AFR
2006 Evo 9
Mods
GSC S1 Mivec cams
Fuel Pump
Tubular 02 housing
11.2 to 10.9 AFR
2006 Evo 9
Mods
Fuel Pump upgrade
Open air filter
GSC mivec cams
11.2 to 10.9 AFR
11.5 AFR
11.8 AFR
2005 Evo 8
Mods
Forge RS BOV
RC 750cc injectors
Cold Air Boxâ„¢
100 cell metal cat
RNR 3" catback
Nisei FMIC & UICP
AMS lower IC pipe
Swain coatings
11.2 to 10.9 AFR
2005 Evo 8
Mods
HKS 272/272 cams
Walboro fuel pump
ETS FMIC
Nisei LICP
3" catback
GST open air filter
100 octane Fuel
11.7 to 11.5AFR
Void,
You can also look in these two threads as well for stock turbo, etc:
Evo 9:
http://www.norcalevo.net/forum/index...c,20262.0.html
Evo 8:
http://www.norcalevo.net/forum/index...c,20172.0.html
Evo 9:
Evo 8:
The dyno he was on was a mustang, but it seems to read a little on the higher side than most.
But, for a 20G and a tune from a nobody... (me)
.... she does pretty good.
Here is my Stock IX Turbo with all bolt ons+ Meth
432hp 497tq
Mods
TTP CUSTOM TUNE
TTP METHANOL INJECTION KIT
WISECO PISTONS
EAGLE H-BEAM RODS
SUPERTECH VALVE SPRINGS
CALICO RACE BEARINGS
MEGAN RACING CAT-BACK
MEGAN RACING DOWN PIPE
MEGAN RACING TEST PIPE
MEGAN RACING 02 HOUSING
AMS COPY FMIC
COSWORTH 272 M2 CAMS
FIDANZA CAM GEAR
HALLMAN MBC(35PSI)
INJEN INTAKE
INJEN UPPER/LOWER IC PIPES
GREDDY TYPE RS BOV
ACT/TTP HDSS CLUTCH
ACT STREETLITE FLYWHEEL
SS BRAIDED CLUTCH LINES
ZEITRONIX WIDEBAND/BOOST/EGT/ZAVT/FAILSAFE
ARP HEAD STUDS
WALBRO 255LPH FUEL PUMP
432hp 497tq
Mods
TTP CUSTOM TUNE
WISECO PISTONS
EAGLE H-BEAM RODS
AMS COPY FMIC
FIDANZA CAM GEAR
HALLMAN MBC(35PSI)
INJEN INTAKE
GREDDY TYPE RS BOV
ACT/TTP HDSS CLUTCH
ARP HEAD STUDS
Im sure u love the way it moves with all that TQ
432hp 497tq
Mods
TTP CUSTOM TUNE
WISECO PISTONS
EAGLE H-BEAM RODS
AMS COPY FMIC
FIDANZA CAM GEAR
HALLMAN MBC(35PSI)
INJEN INTAKE
GREDDY TYPE RS BOV
ACT/TTP HDSS CLUTCH
ARP HEAD STUDS
432hp 497tq
Mods
TTP CUSTOM TUNE
WISECO PISTONS
EAGLE H-BEAM RODS
AMS COPY FMIC
FIDANZA CAM GEAR
HALLMAN MBC(35PSI)
INJEN INTAKE
GREDDY TYPE RS BOV
ACT/TTP HDSS CLUTCH
ARP HEAD STUDS
