i melted a coil pack!?
Old Jul 19, 2008 | 11:36 AM
black E's Avatar
Old Jul 19, 2008 | 05:20 PM
black E's Avatar
bump
Old Jul 20, 2008 | 08:48 PM
black E's Avatar
anyone?!
Old Jul 20, 2008 | 08:50 PM
staatz's Avatar
MY 2nd DLI just **** the bed yesterday took. It's getting annoying.
Old Jul 20, 2008 | 09:09 PM
black E's Avatar
I'm on my 2nd DLI also... HKS replaced the first one under warranty.
Old Jan 19, 2009 | 06:18 PM
Liqquid's Avatar
Good info in this thread, has anyone seen a coil go in this manor on a stock ECU? I'm referring to just one plug, not both from the coil...
Old Jan 19, 2009 | 08:02 PM
boosted2x2's Avatar
something is grounding the trigger for the coil. this is causing the coil to be on all the time and over heat. only the coil who's harness is grounded will be affected. disconnect the ecu take a multi meter test the trigger wire for that coil at the harness plugs if you get a ground signal then there is a problem in the harness or your ignition box.
Old Jan 19, 2009 | 08:20 PM
AcePitcher11's Avatar
Weird. I finally ditched my DLi and picked up a BR cop and never looked back.
Mitsubishi ^_^
Lancer Troubleshooting
11
May 8, 2025 07:48 PM
timmycat
Aug 9, 2017 09:09 PM
11secEVO7
14
Feb 23, 2017 11:27 AM
DemisedGabe
Lancer Engine Tech
Mar 10, 2006 02:41 PM
evosevengsr
15
Aug 22, 2004 06:29 AM
