who makes the light-es IC?
Old Jul 26, 2008 | 10:01 AM
DimitrisIX's Avatar
i thought that the hks type r is quite heavy. it is rated for more than 450 ps in the HKS 2008 catalogue that I got from Tokyo Auto Saloon 08.
Old Jul 26, 2008 | 10:04 AM
Evoryder's Avatar
Originally Posted by Jeff_Jeske
Remove intercooler..... add chemical intercooling system. Gain octane and intercooling all in one shot.
buschur did a test on IC vs no-IC...no IC temps fluctuated vs IC..i think it was w/ 50/50 meth.
I say, go with a ETS cooler + Methanol
Old Jul 26, 2008 | 11:50 AM
black E's Avatar
Originally Posted by JDMIX
^^^ thanks but i still can't get this here....
i did have meth before but i had a malfuntion with my kit were it would spray when the car was off ( intallation flaw) an left me with a bad taste in my mouth, so no more meth for me.
rigth now i'm just runing 25-26 PSI on a street tune.
Old Jul 26, 2008 | 05:21 PM
FILTH's Avatar
I run and recommend the GT spec tube & fin intercooler from Hybrid power.
Core size: 24"X12"X3.1"
Overall size: 32"X12"X3.1"
Inlet/outlet size: 3"
Only ways 6.2kg! Do some reading up about it on the site, with GT35R i gained 15kw @ wheels over my bar & plate intercooler.
They also have the RS Spec which is bigger and rated to 900+ HP and only weighs 8.2kg!
http://www.hybrid-power.com/
Old Jul 26, 2008 | 05:29 PM
FILTH's Avatar
And the best thing...PRICE!
Only $420USD including shipping!!
RS SPEC $483
Old Jul 26, 2008 | 06:35 PM
jbrown's Avatar
No, not heavy at all. I was amazed when I took it out of the box. I have no way to weigh it at the moment, but my guess is no more than 15 lbs.
Old Jul 26, 2008 | 06:53 PM
ECS Performance's Avatar
This is a big issue with us AutoXers as the last place we want extra weight is the bottom front! I would think there is a considerable market out there for a lightweight stock replacement.
-Alex@ECS
Old Jul 26, 2008 | 08:26 PM
black E's Avatar
you can really "feel" all that extra weight up front when you go to a large FMIC.
Old Jul 27, 2008 | 10:42 AM
black E's Avatar
any vendors whant to chime-in the weight of their FMIC ?
Old Jul 27, 2008 | 11:14 AM
DimitrisIX's Avatar
there is a thread an IC weights did you find it?
Old Jul 27, 2008 | 11:47 AM
black E's Avatar
no
Old Jul 27, 2008 | 07:10 PM
black E's Avatar
i've searched all over the place an did not find any info on IC weights.
i guess theres not alot interest in this topic....
Old Jul 27, 2008 | 11:07 PM
JDMIX's Avatar
https://www.evolutionm.net/forums/sh...hlight=weights
the topic is interesting. For me the weight of the I/C is an indication of how easy it cools off after stayiing in traffic for a while. I remember my subaru sti suffered from a heavier I/C (APS) because it could not cool down as good as the stock STI I/C and the car knocked bad. Now the evo has a front mount but I think this principle applies in all applications.
Old Jul 28, 2008 | 11:51 AM
ETS Michael's Avatar
Our 3" intercooler weighs 17lbs where the stock unit is 11-12lbs IIRC. Most of the difference can be attributed to the fact that the stock intercooler is significantly smaller and uses a tube and fin core, where our 3" is larger and uses our bar and plate core. The difference in efficiency and flow is well worth the ~5-6lbs. as most customers report quicker spool/better response and being able to run more boost on the order of 2-3 psi and more timing amounting to at least 5-6 degrees on pump fuel. Consistency is another factor to consider, with intake temps barely fluctuating during repeated hard driving for autocross, time attack or road racing or a full rip through the gears (even repeated pulls) in a drag race
Tom
Old Jul 28, 2008 | 05:01 PM
black E's Avatar
any other vendors want to talk about their IC's?
