rear dif
Old Jul 25, 2008 | 12:34 PM
BleedTheSky's Avatar
rear dif
I own a 2006 silver evo 9. I bought about to weeks ago with about 8300 miles on it. I took my car up to the mitsubishi dealership to get the rear dif fluid changed out today. They told me that there were metal shavings in the fluid they drained. I know that is caused from launching the car. I haven't launched the car myself so this had to be done by the previous owner. I guess my question is does this mean I'm going to have to start looking for a new rear dif?
Old Jul 25, 2008 | 12:44 PM
M3EvoBR's Avatar
depends ... but usually, the pieces are normal...
Old Jul 25, 2008 | 01:27 PM
Jersey Dino's Avatar
you are almost aways going to find metal shavings on the plug when you change any fluids involving the transmission. Trans, and diffs especially. Even if the car was never launched, you will likely find shavings attached to that magnetic drain bolt. its the big chunks that you want to avoid. i had actual peices of gear come out attatched to the bolt on a wrx trans I was working on. now that wasnt good
jmartinez1170's Avatar
Its normal. You will know when your rear diff is about to go out. TRE sells a upgrade for stock diff's for cheap.
Old Jul 25, 2008 | 01:35 PM
Thanks for the info guys. That makes me feel a lot better.
Old Jul 25, 2008 | 04:05 PM
ECS Performance's Avatar
As others have said, it's completely normal.
Old Jul 25, 2008 | 06:09 PM
Ludikraut's Avatar
If you want to be ultra paranoid, take the diff out and send it to TRE for the $400 upgrade ... Jon will check it out while it's there and you will not only have peace of mind, but a lot better handling car. One of the best mods I've done on my car to date.
l8r)
supak1111
Dec 22, 2016 11:35 PM
Nofear23
Mar 3, 2015 05:50 AM
IggyBcool
10
Dec 3, 2014 12:43 AM
Dmav1989
27
Feb 24, 2012 09:31 AM
heingtaing
15
Mar 4, 2011 09:12 PM
