EVO7 Oil temp and Pressure readings
Old Jul 27, 2008 | 05:16 AM
fazzy98's Avatar
Hi....... i use a lightly modded EVO7 as a daily drive. In summer temps are always +40degs C. What is the ideal temp while driving normally? My car always seems to reach about 110 degs C in traffic.... slightly lower normal driving. Spirited acceleration will get it to 120 degs C
I just installed a OP guage and noticed that pressure drops while slowing down from a normal acceleration to less than 1 bar!? Is this normal?
what should be the minimum OP ever on an EVO7? I have a feeling my Oil pump is shot........
Old Jul 31, 2008 | 03:24 PM
R0b's Avatar
R0b
down here in NZ, in traffic, oil gets up to 90deg C and motorway cruizing about 75deg c
air temps here are about 30 deg C though....
Old Aug 9, 2008 | 01:54 AM
exacc's Avatar
My EVO 7 does the exact same thing...EXACT SAME THING...IMHO less than 1 bar is normal duing idle...about .5 to .7 BAR I believe. But when you rev up it has to go up as well. The temp on mine is about 108 during traffic and when I drive it hard 115 to 120.
My issue now is when I use it on the race track it goes up to 150, that I am pretty sure needs to be addressed.
Old Aug 11, 2008 | 10:19 AM
jd323's Avatar
Well, those temps are probably a bit high, but concerning your region of the world, it may be normal. If I lived in an arid and hot region, i'd be fitting a larger oil cooler and upgrading my radiator. Running good motor oil is good too.
Old Aug 28, 2008 | 06:18 AM
xav's Avatar
xav
i guess its normal fazzy98 ....
My evo 7 does 90 deg C in traffic here in beirut, and 110 on a karting track.
Old Sep 21, 2008 | 09:04 PM
kemoly's Avatar
same way in my evo VII!!!
hatakashi
Aug 24, 2015 05:32 AM
mrfred
Apr 9, 2014 05:45 PM
the lambo kille
Jun 13, 2012 11:41 AM
weneversleep
Mitsubishi TC-SST Discussion
13
Jul 14, 2010 06:17 AM
v8k1ller
Apr 20, 2007 09:32 PM
