20g-9-5 or 20g-9-5-lt?
Old Jul 29, 2008 | 03:53 PM
geardog75's Avatar
i bought a turbo off a guy which is in perfect condition he claims its a buschur 20g-9-5 but doesnt know if it the 9-5 lt or the older 9-5 white rabbit. it has the 10.5 hotside. is there anything i can see on the turbo to determine what type or which one it is?
Old Jul 29, 2008 | 05:49 PM
geardog75's Avatar
anybody?
Old Jul 29, 2008 | 06:42 PM
mikiblueeyes's Avatar
WR is not 20g5 turbo.
WR surges like **** at low rpm hight gear.(higway cruize)
20g5 is very close to 9 turbo. (I have one) says FP on it.
Old Jul 29, 2008 | 06:47 PM
sabastian458's Avatar
is it a 5 bladed or 6 bladed compresor wheel?
Old Jul 29, 2008 | 06:52 PM
EVO8LTW's Avatar
Did you have a WR? I don't get surge with mine.
To the OP, look at the turbine wheel and compare it to pictures of Greens on here. The wheel is bigger than the stock one that comes on every other bolt-on turbo (except the Red).
Old Jul 29, 2008 | 07:56 PM
ninekrevs's Avatar
the only difference between the two is that the 20G LT has a larger turbine wheel than 20G 9-5. The 20G 9-5 uses the stock 9 turbine wheel. I would say it is hard to tell visually unless you have a stock 9 turbo to compare it to.
Old Jul 30, 2008 | 02:34 AM
geardog75's Avatar
its the 5 bladed compressor wheel. i called it a white rabbit because thats what forced performance said the 20g-9-5 was when i e-mailed them about a rebuilding a buschur unit. also i noticed the turbine wheel is 12 bladed and the green looks like it has 11 blades.
Old Jul 30, 2008 | 06:21 AM
kim.ry's Avatar
a picture of it would help.
Old Jul 30, 2008 | 07:12 AM
Warrtalon's Avatar
That's BS. That guy knows for sure if he had an FP Green or not, so he is probably just playing dumb to keep whatever money you spent. The price of a 20g-9-5 is nowhere close to the price of an Fp Green (20g-LT).
evox44
Canadian
May 19, 2012 06:50 AM
gmore84
Southeast Region
Nov 5, 2008 06:10 PM
Evo_SpeedKing
Dec 4, 2007 02:37 PM
4DR
41
Nov 25, 2007 12:36 PM
fastassfourdoor
10
Oct 9, 2007 01:55 PM
