Evo Overheating problems Help!
Old Jul 30, 2008 | 08:15 PM
boy8o8's Avatar
Ya my evo is weird. It overheats when im at a stop. but then I turn off the aircon then its ok. In the freeway driving 80 with my aircon is on its ok also but when i drive upwards or like roads going up it overheats. Need help! What do you think is the problem? Checked the fan it works. Help...
Old Jul 30, 2008 | 10:32 PM
boy8o8's Avatar
Help anyone...?
Old Jul 30, 2008 | 10:33 PM
dahuii77's Avatar
radiator my friend................how many miles on it?
Old Jul 30, 2008 | 10:34 PM
boy8o8's Avatar
55k
Old Jul 31, 2008 | 08:15 PM
boy8o8's Avatar
anyone nice to help me..?
Old Jul 31, 2008 | 08:19 PM
bluebanana23's Avatar
I'm assuming you checked your coolant level right?
Old Jul 31, 2008 | 08:33 PM
dude's Avatar
Wow. Where to begin?
Lets start with coolant (mixed with distilled water). Check your overflow tank and add as necessary.
If that doesn't work let's try the radiator cap and thermostat. Those are cheap and easy to replace.
If that doesn't work, check the water pump (this is more advanced). Based on your current knowledge I'd say go with a pro on this one.
If that doesn't work, check for the milky stuff on your dipstick. If present, change your headgasket, oil and coolant.
If all of the above doesn't work, buy an electric car.
Old Jul 31, 2008 | 09:13 PM
yellowevo82's Avatar
Def check your water pump its a mess when they go! Change your fluid.
Old Aug 2, 2008 | 02:30 PM
boy8o8's Avatar
ok thanks for the help...
Old Aug 2, 2008 | 03:11 PM
john.schuber's Avatar
Koyo Radiator
Old Aug 2, 2008 | 04:28 PM
EVOLVEU's Avatar
Def one of these, or your radiator fan. Make sure its turning on.
Old Aug 2, 2008 | 05:03 PM
highhats's Avatar
radiator fan is not turning on bad fan or relay.
S
Old Oct 15, 2008 | 06:34 AM
crazybaldhead's Avatar
Check your grounding! If you have an aftermarket gauge you will see that the temps are fine. The stock gauge will read high when the second fan comes on at about 97 deg celcius. When the fan comes on the sensor does not get a good ground and reads high.
Get some cheap 4awg black wire and ring terminals, ground the battery to the chassis ground points near the headlight and near to the battery.
Cheap fix for an annoying problem.
This is all assuming your rad/fan/waterpump is OK.
cbarnicle
May 29, 2011 08:00 PM
EVO(boss)
Jan 3, 2010 09:02 AM
southpaw
Jun 10, 2008 01:01 AM
fromgsx2evo8
Dec 20, 2004 11:04 AM
350ZTrack2Evo8
16
Jul 9, 2003 07:37 AM
