Vac/Boost Problem?
Old Aug 6, 2008 | 12:19 PM
Redline-Z's Avatar
Veteran: Air Force
Vac/Boost Problem?
Yesterday I noticed when I started my car that my Vac was only -13 when usually it is -17. So I started driving to work and once the car got warm I hit it, it only hit 11 instead of 24. It also surges up and down quickly between 6-11 psi
So I turned off my EBC and should of been running wastegate pressure of 11.5psi. I am only seeing 6psi in 5th gear instead of 11-12, no surging, just won't boost.
Now other than a boost leak, which I am going to search for this weekend, any ideas? I know it could be alot of things I am just looking for feedback on what to look at first.
Old Aug 6, 2008 | 12:24 PM
denver's Avatar
I think you are on the right track with a boost leak, look at the hoses on the backside of the intake manifold. They tend to blow off a lot.
Old Aug 6, 2008 | 12:25 PM
ddfelix5494's Avatar
+1
Old Aug 6, 2008 | 12:26 PM
SLO-EVO's Avatar
+1 to boost leak test
also check the couplers for tightness...
Old Aug 6, 2008 | 12:28 PM
Redline-Z's Avatar
Veteran: Air Force
Good ideas guys all will be checked, also when I installed my EBC I mini zip-tied everything tight. Everything looked good from above, I just have to take out my ARC box and get underneath it and check out the AEM solenoid.
Old Aug 6, 2008 | 12:38 PM
OhsixIXBish's Avatar
+1 on all the boost leaks. I had a plug in my stock intake tube and i raced a sti in oc and i was using the 2 step off the line and the plug blew out of the intake tube i didnt know it. My boost gauge said i was pushing 11psi when i know i was pushing well over 20 that was my prob. Just look over everything real good +1 to all that posted above! good luck let us know what you find.
Old Aug 6, 2008 | 12:52 PM
Redline-Z's Avatar
Veteran: Air Force
I have a plug in my intake also, ill check it in the morning. Would of never thought of that yet I didn't see it when I looked in.
Old Aug 6, 2008 | 12:53 PM
Yeah is urs like a the aluminum plug with a hose clamp around it?
Old Aug 6, 2008 | 01:04 PM
Redline-Z's Avatar
Veteran: Air Force
I removed it and plugged it off. I'll check it.
Old Aug 7, 2008 | 04:24 AM
Redline-Z's Avatar
Veteran: Air Force
FOUND IT...Damn animal got me? Took out my boost sensing line and my washer fluid line is missing 8 inches of rubber. The one night I park outside and something chews me up This will be fun going over everything trying to find more damage.
Old Aug 7, 2008 | 10:03 AM
Redline-Z's Avatar
Veteran: Air Force
Im lucky he didn't go to town on my engine! happens alot over here.
http://images.google.de/imgres?imgur...%3Dde%26sa%3DG
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Dec 17, 2010 09:41 AM
Tanman1986
Jul 19, 2010 07:26 AM
riceball777
Dec 15, 2006 07:50 PM
hawaiievo
20
Sep 8, 2005 05:48 PM
djmikeymike
Jun 12, 2005 04:52 PM
