Help Me Please!!!!!
Old Aug 23, 2003 | 12:00 AM
NEADmike's Avatar
Help Me Please!!!!!
Just installed ACT Clutch. Car won't go into gear when car is started. Car will go into gear when off. When the car is started, it sounds like the release bearing is rattling really badly. Almost seems like the clutch isn't disengaging. Any ideas on what to do? Is there anyway to adjust the clutch pedal? HELP ME!!!
Best regards,
Mike
NorthEast Auto Design
www.ForPerformance.com
www.NorthEastAutoDesign.com
1.800.296.6560 ext. 202
Old Aug 24, 2003 | 10:36 PM
timzcat's Avatar
The clutch is not releasing, it sounds like the throw out bearing is not installed properly.
Old Aug 26, 2003 | 11:15 AM
Mad_SB's Avatar
Did you bleed out the clutch ?? If you have air in the line (enough air) it won't disengage the clutch.... hope it's that and not what Timz mentioned!!
Old Aug 26, 2003 | 01:12 PM
evo 8 ya's Avatar
Just installed ACT Clutch?
i didn't even know that ACT made a clutch for the evos yet. ****, if they do i'm ordering one tomorrow
Old Aug 26, 2003 | 03:13 PM
timzcat's Avatar
They don't yet. They had a small run of them which ACTman had posted, but I am sure they were all scooped up.
If there is air in the system the pedal will be dead at the top, if you don't have freeplay at the top then you probably have no air. I will say this, once you get air in it, it can be a ***** to get it out.
Old Aug 26, 2003 | 11:34 PM
QuantumEVO's Avatar
That wouldn't account for the rattle, though.
Old Aug 31, 2003 | 01:49 PM
skbydoo's Avatar
If the clutch needs to be adjusted. On the top of the clutch pedal inside the car there is a brass looking nut that can be backed off and then a brass looking rod that can be pushed forward or back then tighten the nut. I'm not sure if this is your problem but that is how you adjust the clutch.
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
silverevo05
Dec 11, 2013 09:48 PM
rcgoff2
18
Apr 2, 2013 10:06 PM
YoManStation
23
Dec 10, 2012 06:52 PM
binky
24
Aug 16, 2009 06:08 PM
