Exhaust Bolts
Old Aug 8, 2008 | 10:37 AM
mr1444's Avatar
Exhaust Bolts
Can someone tell me what the torque specifications are for the exhaust bolts?
Old Aug 8, 2008 | 10:44 AM
madmax4499's Avatar
i found this.
Exhaust manifold
Air outlet fitting bolt 19 ± 1 (14 ± 1 ft-lb)
Engine hanger bolt 19 ± 3 (14 ± 2 ft-lb)
Exhaust fitting bolt 59 ± 5 (44 ± 3 ft-lb)
Exhaust fitting bracket bolt 36 ± 5 (27 ± 3 ft-lb)
Exhaust manifold heat protector bolt 14 ± 1 (124 ± 8 in-lb)
Exhaust manifold nut M8 29 ± 3 (21 ± 2 ft-lb)
Exhaust manifold nut M10 49 ± 5 (36 ± 3 ft-lb)
Oil pipe bolt (eye bolt M10) 17 ± 2 (13 ± 1 ft-lb)
Oil pipe bolt (eye bolt M12) 31 ± 2 (23 ± 1 ft-lb)
Oil pipe bolt (flange bolt) 11 ± 1 (98 ± 8 in-lb)
Oil return pipe bolt (oil pan side) 14 ± 1 (124 ± 8 in-lb)
Oil return pipe bolt (turbocharger side) 9.0 ± 1.0 (80 ± 8 in-lb)
Oxygen sensor 44 ± 5 (33 ± 3 ft-lb)
Turbocharger assembly and pipe assembly bolt, nut 64 ± 5 (47 ± 3 ft-lb)
Turbocharger heat protector bolt 14 ± 1 (124 ± 8 in-lb)
Water pipe bolt (eye bolt M12) 42 ± 7 (31 ± 5 ft-lb)
Water pipe bolt (flange bolt) 10 ± 1 (89 ±
Old Aug 8, 2008 | 11:01 AM
mr1444's Avatar
Thanks for the reply...this really helps a lot!
Old Aug 8, 2008 | 01:36 PM
Spish's Avatar
German torque.... Gutten tite.
Old Aug 8, 2008 | 02:12 PM
chaotichoax's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=222551
it's a sticky
search first next time
closed...
bruiselee
May 28, 2016 05:25 AM
newevoxguy
Jan 23, 2015 04:10 PM
overdrive1
Nov 10, 2014 06:03 PM
aduke05
Feb 19, 2011 08:48 PM
andrewRA
May 30, 2010 05:16 PM
