FP RED vs 35R
Old Aug 18, 2008 | 05:15 AM
  #136
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by PsychDr. HN$
Let me claify, IM NOT DISSING THE 35R. I love the 35R and i WAS seriously eyeing one until the RED came out. What im saying in regards to power, that on a full bolt on car this turo can make pretty close to 500whp. We have already seen what this turbo has done on an all-out buschur car on race gas (530-ish i think. i gotta find the thread again). If you just made 530ish on your RED and you want more then the 37R may be your next step instead of the 35R. to me if you already have a RED with a built motor and want more power then the 37R is the way to go.
This is just a comparison/debate/informative thread on two great turbo options that we have.
Well since the evo is the 8 sports car I have owned I fell the same way. I only want to make 500whp and I don't push my car hard all the time so the FP red is the best choice for me. If I make 4:20whp on 93 I happy then with 100% meth then 500 is the way to go. I'm not trying to doing a motor build I'm trying to make big HP and keep the stock motor reliable.
Old Aug 18, 2008 | 05:33 AM
  #137
SPANKED's Avatar
Good debate guys but I think I'm sold on the simplicity and spool of the Red.
Old Aug 18, 2008 | 05:35 AM
  #138
Nomad4g63's Avatar
heres a simple way to look @ it
FP RED:
Non built just basic boltons & what not 440-480 MAX!
Build the motor and u might get over 500 hp
HTA35R:
Boltons non built 480-520
Build the motor 480-700
How can you compare a turbo that maxes out @ 520 or so to a big turbo that maxes out @ about 700 whp???
I know what your trying to do tho ur trying to see which turbo is the best to make 500 hp like most other people in here. My advice is u wanna go cheap to make that power get the FP Red, but if 1 day u wake up and say i want 550 there is no turning up the boost like u can on a 35r to make that
Old Aug 18, 2008 | 07:13 AM
  #139
93 3gt vr4's Avatar
FP RED:
HTA35R:
Boltons non built 480-520 < @ 9000rpm with 5 tq
Build the motor 480-700 < @ 8900rpm with 6 tq
I think this turbo is what a lot of people been looking for! Doesn't make sense to do a 35r unless you build you motor and rev to 10million rpms. imo. and the only comparison of the two would be on pump with stock engine. How about a 30series turbo VS. the red.
Old Aug 18, 2008 | 10:54 AM
  #140
PsychDr. HN$'s Avatar
FP RED:
HTA35R:
Great point but ive personally seen many stock block 35R powered evos NOT make 500whp. I would still think that on stock block and 93 the RED would def spool up a lot faster too. I think the diff of the two is really seen on built motors. REALITY is that there are prolly more stock block 35R evos out here than built. I would also say that there are more reg 35R's out there than HTA35R's. A quick spooling, stock looking turbo, for less than 2k, and can make 450whp+, is a winner in my book all day long. I wouldnt say its a CHEAP way to go. I just think that its a very cost effective way to go. AGAIN i like both turbos but 1799 vs 3499 says a lot to me, especially if on stock block im losing 30whp but gaining quicker spool-up(using your numbers). Even more, if we are both leaving the SHELL gas station after pumping 93 and we just happen to end up next to eachother at a stoplight. I dont wanna hear, "wait till I build my motor and turn up that boost".
AGAIN my opinion but I feel that if u plan for a motor build go 35R or better. If not, FP RED or "lower". So far, the power is just too close on a stock block for the price difference.
Eitherway, Im glad that the RED is for and not everyone else. I feel even better knowing that the only other car that i would have to be concerned with from a dig is ANOTHER EVO
Old Aug 18, 2008 | 11:04 AM
  #141
Rexpeed's Avatar
Originally Posted by 4G63W8
Hi,
If it's you Derek posting,nice to see you on here as well,if it's your partner posting and it's you who is getting the red, then man give Derek my regards.
As far as the red bolting on,the only that you need is the boost pipe(the black pipe with the flange that is connected to the cold side of the turbo,the compressor,and on it's other side leads to a hose that is connected to the intake intercooler pipe),you don't need the water and oil lines as you can bent slightly the existing ones to adjust them to the turbo.
I even used the viii boost pipe by cutting the flange of it and welding it in onother angle so as to match it with the green.
This is if the car is a VIII if it's a IX then it's a straight bolt on.
cheers,
Marios(4g638-MLR)
Hi Marios,
Yes this is Derek
My partner is looking for an turbo upgrade and im just trying to help him pick one that is good for street use.
Thanks for all the help guys
Derek
Old Aug 18, 2008 | 11:07 AM
  #142
Rexpeed's Avatar
One more question
Do other vendors carry this RED turbo or do I have to order it online from FP?
Thanks,
Derek
Old Aug 18, 2008 | 11:28 AM
  #143
93 3gt vr4's Avatar
Fp and buschur are selling them. Don't know if anyone else is. But there is a waiting list.
Old Aug 18, 2008 | 11:29 AM
  #144
93 3gt vr4's Avatar
Originally Posted by Rexpeed
One more question
Thanks,
Derek
Old Aug 18, 2008 | 11:34 AM
  #145
Shacochis06's Avatar
go thru buschur i got mine in less than 3 weeks
Old Aug 23, 2008 | 11:17 AM
  #146
ecuflasher's Avatar
Originally Posted by CO_VR4
I have a mismatch in flanges on the downpipe to exhaust joint that will take a few days to have modified and TIG'd into matching up, and some AEM map changes to get the transition from the 35R maps to the new maps in shape, then I should be ready for startup again. I made a few more changes to the system than just the turbo swap, so the small things slow you down, sometimes. Work gets in the way of car modding sometimes, too...
As far as the smiley faces, well, that's just anticipation There will be more when the car fires up...
Any review on the EvoRed?
Old Sep 16, 2008 | 03:51 PM
  #147
hokiruu's Avatar
Since this thread was retarded to begin with, but I happened to stumble upon this video of a relevant race, I thought I might post it here.
-Two 2.0 Evo VIIIs
-Full Race twin scroll 35R vs. FP Red. Most are familiar enough with Evodan2004's setup to know that besides the turbo kit, it's a pretty mildly built car.
-35R is on pump, Red is on E85 (huge fuel advantage)
http://www.youtube.com/watch?v=nyt-MfMUS-M
I rest my case.
Old Sep 16, 2008 | 06:38 PM
  #148
chrisblueevo's Avatar
-Two 2.0 Evo VIIIs
I rest my case.
How much power was the red making?
Old Sep 16, 2008 | 07:52 PM
  #149
EVO8LTW's Avatar
Over 450 whp on Buschur's dyno.
Old Sep 16, 2008 | 08:16 PM
  #150
Q8_EVO's Avatar
guys ... i 'didnt' search lol i admit this
is it worth switching from green to red ?
flame suit on
