Car won't start, randomly.
Old Aug 15, 2008 | 11:43 PM
boostedawd's Avatar
This is so weird. My car won't start at random times. It would be perfectly reliable for 3 weeks, then one day, it won't start. It's only happens after i've driven the car and stopped for a short while (restroom or to get some food). It never happens in the morning when i first start the car. Battery was checked as fine, and there isn't any water damage from the common leaking area. It acts exactly like my clutch pedal isn't pressed and i try to start the car. everything electrical works, but the car just won't turn over. It won't even try to crank.
Btw, It will EVENTUALLY start after i try to start it several times. But it takes several tries.
I have two gauges (boost, a/f). The a/f doesn't work, but lights up. I also have a turbo timer (apexi). What's weird about this TT is that it goes into a small black box, which connects it to the ignition wires, and several other wires that im not sure of. Anyways, i don't think it has anything to do with it because the problem happens even if i turn it off.
any help guys would be appreciated. thanks.
-dan
Old Aug 15, 2008 | 11:51 PM
randomae's Avatar
Who installed the turbo timer?
Old Aug 16, 2008 | 12:12 AM
EvoHung's Avatar
Check your tt wires inside your steering column.
Old Aug 16, 2008 | 12:28 AM
evo_q8's Avatar
something exactly the same happened with another evom member - Shocky.
He had some issue with some clutch switch something.. will ask him to reply here..
Old Aug 16, 2008 | 07:00 AM
EvolNinja's Avatar
+1 It's gotta be a loose wire somewhere in the steering column. Did you use a turbo timer harness that is made for the Evo?
Old Aug 16, 2008 | 07:07 AM
Evoryder's Avatar
Or it could be some other sensor on it's way out.
Old Aug 16, 2008 | 07:29 AM
MEVOLV3's Avatar
i'd put my money on that...my buddy's srt-4 had identical symptoms as the op described and it turned out to be a clutch pedal switch or something along those lines. i will have him give me more detail and post it up asap
Old Aug 16, 2008 | 10:01 AM
boostedawd's Avatar
im not sure if it's my clutch pedal switch because i've disconnected it before, and it won't start.
THis means, that i can start the car without pressing the clutch. But with this issue, i still can't start it no matter if the clutch switch is connected or not.
Old Aug 16, 2008 | 10:13 AM
boostedawd's Avatar
The TT seems to be connected using a harness.
Old Aug 16, 2008 | 12:10 PM
andreww238's Avatar
could be a loose connection.. check your battery cables also..
Tannels
Lancer Troubleshooting
Sep 19, 2016 07:33 AM
XinnKoda
Feb 1, 2016 08:58 AM
Wmu240
Dec 18, 2015 10:18 AM
Night12000
Sep 28, 2015 08:03 AM
bboyirra
Sep 17, 2013 11:55 AM
