is it ok to drive with a blown exhaust manifold gasket?
Old Oct 23, 2008 | 10:36 AM
SlowScooby's Avatar
Don't drive to long with a leak like that. You risk warping the manifold or burning your valves. Not to mention burning something up in the engine bay with the extreme heat.
Old Nov 10, 2008 | 05:46 PM
srtboostin22's Avatar
35$ for the gasket and about 30 min tops of install :]
Old Nov 12, 2008 | 08:19 AM
EvoDom's Avatar
exhuast manifold is a bi$#h to get off. buy an oem gasket there the best. do it yourself with a 12 pack and and the radio on haha and watch you dont fry your valves.
Old Nov 12, 2008 | 08:26 AM
MSP608's Avatar
Not sure if it was from my manifold leak, but I fried a coil this weekend at Summit Point after doing a session with a nice chunk of my manifold-turbo gasket missing on the passenger side. I got a replacement coil and drove it easy back home no problems.
Should be ok to move around but I wouldn't get on it too much.
I don't know why I even bothered putting on Megan gaskets, should have bought new OE stuff.
Old Nov 23, 2008 | 06:55 PM
sonicnofadz's Avatar
Removing the manifold is pretty easy if you've done it before. Buy a set of new gaskets (two for the turbo, one for the head/manifold). You can drive indefinitely with a blown manifold gasket but you will be down on power and performance (turbo will not spool up as quick, and your top end will be lower). Just find a DSM guy to help you with the gasket install, they know this process all too well.
Old Feb 27, 2016 | 04:58 PM
HarcoEvo's Avatar
Sorry for reviving an old thread. Can you replace the gasket where the manifold meets the head without having to undo the bolts at the opposite end of the headers? Basically, can I undo the bolts where the manifold meets the head and pull the manifold off the studs to fit the new gasket?
kkeller
May 3, 2017 11:22 AM
boost556
24
Mar 31, 2016 01:08 PM
Chaoticx2
Mar 9, 2016 12:35 AM
ferrari99
Feb 29, 2016 10:11 AM
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
