Hi guys,
Did a search but could only find people with blown fuses.
So both the cig lighter and the 12v outlet stopped working on my '09 ES. I have a dashcam plugged in, and one time I connected it, it turned off and had a blown fuse. No biggie, changed the 15A fuse, and it worked fine.
Second time it happened though, I checked the fuse and it was fine. Switched to the 12v outlet, used it like this for 2 weeks, and bam, it stopped working, but no blown fuse. Now both don't work, and I've tried other devices and they don't turn on (So it isn't the camera).
Is there an additional fuse I should be looking for? Thanks.
There is a relay and fusible link. I doubt its the fusible link since you have checked for 12v at the fuse.
