FP Red Question???
Old Aug 21, 2008 | 09:58 AM
  #31
Jspec EVO VIII's Avatar
The Red's a promising turbo, people already have dyno sheets and such on barely built blocks or anything of the sort, being around like 370 ish hp on one. I placed a order for mine around the same time 7-22, but have since cancelled that order since it didn't make any sense for me to wait that long when i can have a better turbo for me in my possession.
There's a thread floating around about in PR, the Red has already made like 600hp. The E85 one is just crazy as well, 525hp. Hopefully they make it out to the track and get some times.
Old Aug 21, 2008 | 10:12 AM
  #32
2highpsi's Avatar
I have put a thousand miles on mine so far. 4 runs down the 1/4 mile, an hour on a dyno, and a good bit of "spirited driving". No problems so far.
Old Aug 21, 2008 | 10:35 AM
  #33
SPANKED's Avatar
So for straight pump gas the green is still a better choice?
Old Aug 21, 2008 | 10:36 AM
  #34
Warrtalon's Avatar
That's entirely up to the individual. For some, no. For others, yes. I personally think neither should be used on pump gas, because their biggest gains over the stocker are seen at high boost levels. Both have a lot of wasted potential when relegated to pump gas use only...
Old Aug 21, 2008 | 12:37 PM
  #35
STIKILLA1084's Avatar
Well i'll wait alittle bit longer too hear,what everybody thinks before I decide what I want to do.I appreciate everybody comments.
Old Aug 22, 2008 | 12:44 PM
  #36
raevo9's Avatar
what kind of gaines would you expect just by bolting a green up and replacing a stock turbo, with my mods.
Old Aug 22, 2008 | 01:26 PM
  #37
1sik _evo8's Avatar
i got prob on my red.i wont comment for this right now till il get hold of FP
Old Aug 22, 2008 | 01:32 PM
  #38
Warrtalon's Avatar
Not a lot if you are just using pump gas - maybe 20-30whp. The Green and Red shine most when running big boost, which requires octane enhancement (alky/meth injection, race gas, or e-85).
Old Aug 22, 2008 | 06:29 PM
  #39
2highpsi's Avatar
I was going to mention that you CAN run big boost on 93. However I guess if you have the mods and tuner that allow it to be possible, you would already know that. So for the guys that are asking that question you are right. For that reason I won't argue it...
Old Aug 22, 2008 | 06:40 PM
  #40
Warrtalon's Avatar
Yes, we're on the same page. You can't do it with basic mods and tuning, but with everything built up, you can run quite a bit of boost on 93oct (i.e. Buschur 3 Amigos).
Old Aug 22, 2008 | 06:44 PM
  #41
diiirk@AwdMotorsports's Avatar
I disagree that the green is not a good pump gas turbo. I guess I just have the right mods then. And good tuner.
Old Aug 22, 2008 | 06:58 PM
  #42
Warrtalon's Avatar
Perhaps you do. Your results are not typical on pump gas for a stock motor. You should see a much bigger gap between pump and race gas as the race gas allows a lot more boost + timing and leaner AFRs. In your case, you gained a lot more torque from running a lot more boost, but half as much WHP, which shows your pump gas boost is already pretty aggressive. That tells me you have a good setup, and it was tuned well.
Old Aug 22, 2008 | 09:00 PM
  #43
Zeus's Avatar
You think?
Seriously, I can't say enough good about John's OE ECU tuning... now I just have to convince him to "remote" tune me on E85, then again on E85 and the Red.
Old Aug 22, 2008 | 11:57 PM
  #44
mojo's Avatar
My red shipped today. FP called and said they could ship today if I take off porting option which I did. They said that they were taking the porting and coating option off the website as it was causing orders to backup. I think that may be just for the red. They said they would complete peoples orders that had originally wanted porting and coating but it would just take longer. Anyway they must have received their new shipment of compressor housings because last I spoke with them that was what they were waiting on to complete orders. My original order was placed on 7/17 and I originally had ordered it ported and coated.
Old Aug 23, 2008 | 02:33 AM
  #45
sinpul's Avatar
^^^ Great to hear! Hope to see you post some great numbers on the board. Good luck with the ride!
