What is the stock boost pressure of the 8
Old Aug 25, 2003 | 10:36 AM
Crazy4Cars's Avatar
Anybody with an aftermarket boost gauge, please let me know what is the stock boost pressure?
Old Aug 25, 2003 | 10:38 AM
Guru_Del's Avatar
19.5 psi (or so) but a search would have yeilded you the same answer. it tappers off towards redline
Old Aug 25, 2003 | 11:09 AM
GTVEVO's Avatar
The stock boost pressure according to the manual is 18.5 not including any boost spikes. This is also talked about in the video that you are suppost to watch before they turn you loose in your car. 18.5 and it is set to taper back to 16. I measured mine when I got it and I seen it spike up to 19 and drop as low as 15.5 due to weather conditions and such. 1.275 bar is what your gauge will show stock at 18.5psi.
Old Aug 25, 2003 | 08:44 PM
EVO-Bill's Avatar
When my EVO was stock it would max out at 19psi and then drop of to 16 at about 5000rpm.
Old Aug 27, 2003 | 01:33 PM
David Buschur's Avatar
The stock boost is 19 psi peak, this will hold until around 4,000 rpm when the factory computer/boost selonoid drop the boost to 16 psi until redline.
David Buschur
www.buschurracing.com
Old Aug 27, 2003 | 04:08 PM
xtnct's Avatar
Anyone might have any ideas why I only see 16psi max tapering off to 15 at red line? My car is stock. I can think of the following:
1) incorrectly calibraded gauge
2) a boost leak
I don't really have the energy to look for a boost leak right now, but would not mind borrowing another gauge to see if it reads right though....
Old Aug 27, 2003 | 04:21 PM
hel_if_ino's Avatar
boost leak, or problem with the solenoid.. but you would only see 11lbs if that were the case
Old Aug 27, 2003 | 11:09 PM
GTVEVO's Avatar
First I would check your gauge.You might be able to swing a check up with the dealer to test your boost pressure to your guage since the gauge is reading low to make sure it is accurate. The dealer can tell buy hooking up a DRB or somthing simmilar to your car and taking it for a test drive.
Old Aug 29, 2003 | 01:39 PM
TRDHarrier's Avatar
Mine pumps up to ~1.32 bars and then tapers to 1.2
Old Aug 29, 2003 | 02:07 PM
JRock's Avatar
The equation to get pounds from BAR is just multiply by 14.5, right?
Old Aug 30, 2003 | 07:56 AM
Changy's Avatar
Out of the box
GuamEVO
13
May 4, 2011 03:33 PM
djd24
Dec 16, 2006 12:53 PM
SSKILLA
Oct 2, 2005 01:10 PM
rt turbo
Nov 10, 2004 09:32 PM
pkjing
Oct 28, 2004 06:56 AM
