? for those who have removed the OEM EVO 8 intake manifold...
Old Aug 24, 2008 | 10:22 AM
riceball777's Avatar
get ready to hate your life. im removal and install on a evo is very hard. i remember the first time i did it it took me most of the day.
Old Aug 24, 2008 | 06:41 PM
Blue Evo 8's Avatar
Well, I have some good news, everything is almost back together. I couldn't bang everything out in one day though... I worked on the car like 3 hours saturday and 3 hours sunday... Tomorrow I will do the finishing touches and fire up the car.
the only thing that I could not do on my own was remove the 14mm intake manifold bracket bolts, but my brother got them out for me.... I managed to get the rest of everything out myself.
While the manifold was out I put in a phenolic intake manifold gasket (old Honda trick I did on my Integra once upon a time), and I also removed the oem EGR valve, and slapped on the Buschur Racing aluminum blockoff plate. I also removed the intake manifold bracket as well, and probably saved like 1-2 pounds....
The next thing I gotta do is on the 65mm T-body is set the TPS to the correct voltage readings, and I will then think about doing the throttle body coolant bypass also....we'll see...
Old Aug 24, 2008 | 06:43 PM
ExViTermini's Avatar
Your rocking the EMS, no need to worry about the voltages, just hook up the laptop and do the TPS wizard cal thing...
Old Aug 24, 2008 | 06:46 PM
Blue Evo 8's Avatar
I'm not sure how to do that, what menu do I go to the set that up?
In the meantime, I'm gonna look at the position of the TPS on my stock t-body, and make sure it looks, lines up the same on my BR t-body.
Worse come to worse I'll have my brother set it for me... he has one of those tools... that we can set the TPS thing with...
Old Nov 27, 2016 | 10:51 PM
2rbolag's Avatar
you'll burn that phenolic gasket if you didn't tap the egr port at the head where 900+ degree exhaust gases travel thru
Sorry for the thread revival
Old Nov 29, 2016 | 08:56 AM
I've done many without plugging that hole, no issues.
Old Dec 6, 2016 | 01:06 PM
Blue Evo 8's Avatar
Thanks for clarifying !
Veronica
May 18, 2017 01:09 PM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
54
Mar 13, 2017 01:27 AM
bakuro117
43
May 12, 2016 02:23 PM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
