Turbo doesn't spool high anymore
Old Aug 22, 2008 | 12:24 AM
ellyottlin's Avatar
Recently i put a cel fix on the o2 sensor for the test pipe. It used to run at 1.7 bars. now it runs at .8 bars. please help on this. I disconnected the battery while installing the o2 sensor. The cel is still on too. thanks
elliott
Old Aug 22, 2008 | 05:11 AM
JakeTheVIII's Avatar
If you had your battery disconnected for a while, you should have no CEL when you start your car back up, as I think it takes like 30+ miles (might be wrong) for it to come back on. What kind of CEL fix did you use?
Old Aug 22, 2008 | 07:39 AM
Warrtalon's Avatar
If all you did was add a CEL fix to the REAR O2, then that would have no bearing on boost. To be seeing .8bar, it would mean you are on base wastegate pressure, which means your boost system is not hooked up.
Did you verify that the current CEL is still the rear o2 CEL?
Old Aug 22, 2008 | 08:34 AM
ellyottlin's Avatar
the cel stayed off for around 30 miles then came back on. I used the adapter for the o2 sensor on the test pipe.
where is the boost system located?
Old Aug 22, 2008 | 08:55 AM
EvoBroMA's Avatar
nowhere even near the test pipe/secondary o2. its about a mile away. really.
Old Aug 22, 2008 | 09:59 AM
rolly1818's Avatar
Registered User
Wastegate!
ur boosting to 11psi, thats wastegate boost.
Old Aug 22, 2008 | 10:05 AM
holler mcdollar's Avatar
nothing to do with the CEL fix... it's gotta be something else you're not mentioning/thinking of.
Old Aug 22, 2008 | 12:37 PM
ellyottlin's Avatar
It was running fine when I first put on the o2 sensor. Then after boosting it a couple times it stopped boosting to 1.7 bars. I didn't touch anything else. Is something broken???
Old Aug 22, 2008 | 01:13 PM
BBS's Avatar
BBS
Please listen to what people are telling you. You're running waste gate pressure. That means your solenoid system is not connected or your wastegate flap somehow disconnected off the actuator arm.
Old Aug 22, 2008 | 01:22 PM
ellyottlin's Avatar
I'm sorry. I'm new to the evos. Where can I locate the solenoid system and wastegate flap? Thanks
Old Aug 22, 2008 | 01:24 PM
joedr's Avatar
EvoM Moderator
I can not tell from the narrative if the boost problem happened right away after installing the O2 CEL fix or later on. My guess... is that it happened later on.
Please have a knoweldgeable mechanic, that dealt with bleeder boost control systems before, to take a look at the wastegate/solenoid area.... BTW, any reputable shop will be able to assist you on that matter fairly easy.
My advice is that you do that or if you feel that you can hadle the troubleshooting, find a Service Manual to assist you to diagnose the problem. This issue has been discussed a lot before and in many occasions is a solenoid/wastegate hose that got disconnected or it is leaking air.
So far with the info provided.... the boost issue is no related to the O2 CEL fix.
Good luck!
Old Aug 22, 2008 | 01:31 PM
joedr's Avatar
EvoM Moderator
Here is where the wastegate actuator is located at.... it is the golden "cup" towards the radiator.
The flap is inside the turbine side of the turbo.
rich3389
Aug 12, 2014 09:55 AM
luvboost
Mar 24, 2011 10:15 AM
Silverfox742
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 12, 2008 10:28 AM
shunderwunder
Nov 30, 2007 04:11 PM
Ralliart Lancer
Apr 6, 2006 07:29 PM
