False knock, stock ecu, built motor
Old Aug 22, 2008 | 04:11 PM
DS-03evo's Avatar
I have a fluidamper that will not fix the problem it you!
You will have to reduce the sensitivity of the knock sensor somehow, either mechanically or electrically.
Old Aug 22, 2008 | 04:24 PM
Erik@MIL.SPEC's Avatar
That may be your experience, but others have different experiences.
He should try it and see what happens
Old Aug 22, 2008 | 07:56 PM
ecuflasher's Avatar
Originally Posted by Erik@MIL.SPEC
Well, it might help fix the problem. At less than $300, it's probably an inexpensive idea to try since IMHO the upside to fixing that issue is huge.
There are a few people with built motors running these who are able to use the stock ECU because it eliminates a lot of the vibration.
I know whan I do my stroker that I will have one of these put in.
I have a fluidampr but I still get alot of false knocks.
Old Aug 22, 2008 | 09:08 PM
Guys, I didn't say the thing was a panacea...I just said it's helped some people combat the problem.
Old Aug 23, 2008 | 01:51 PM
Ludikraut's Avatar
$300 < $1000+
Yes, the AEM can remedy things but you're better off trying the damper first...especially since an AEM would require a new tune
Understood, but since the $300 (+install) investment isn't a guaranteed fix, it's not as clear cut of a decision, because 300 < $1000+ < 300 + 1000+
l8r)
Old Aug 24, 2008 | 11:34 AM
DS-03evo's Avatar
True, it worth a try i guess.
Old Aug 24, 2008 | 11:35 AM
DS-03evo's Avatar
To everyone that is seeing major false knock counts. What RPM is it happening?
Old Aug 24, 2008 | 12:51 PM
I wonder how much this has to do with the engine build too, and how loose and/or tight the engine was kept to OEM specs. Don't know, just asking the question since some seem to have this problem and others don't.
Old Aug 24, 2008 | 02:34 PM
tvor's Avatar
It may be the case, the engine was built pretty damn well, actually it is perfect and no smoke, burnt oil or anything. Very smooth and solid. I am still thinking about using a rheostat to turb down the voltage being reported back to the ECU, but again how useful is the knock control at that point...
my knock is happening from 4500-8k usually, under high loads. This is most likely the cause of taking the balance shaft out more than anything.
Old Aug 24, 2008 | 02:56 PM
gamebred26's Avatar
This happened to two people I know with built motors tring to run on the stock ECU. Both ended up going AEM to solve it.
Old Aug 24, 2008 | 03:02 PM
ray3328's Avatar
I had the same problem after my engine was built and went with AEM. If you want to keep the stock ecu I have a new fluidamper I never used if you want it send me a offer.
Old Aug 24, 2008 | 03:14 PM
I would think that no smoke/burnt oil from the engine doesn't necessarily correlate to the specs/tolerances of the engine.
Old Aug 28, 2008 | 12:56 PM
sluflyer06's Avatar
up to the top.
Old Aug 28, 2008 | 04:29 PM
DS-03evo's Avatar
That's the easy way out.
Old Aug 29, 2008 | 05:59 AM
gamebred26's Avatar
true but if you are building a motor a standalone is the next step.
