Clutch engagement changing randomly
Old Aug 22, 2008 | 07:11 PM
Toxin's Avatar
Hey everyone,
Another problem and here I am again, asking for help. I recently installed an Exedy Twin and it was not getting into gear properly and the car nudged a bit when putting it in to first. I opened a topic about it and got a bunch of ideas how to fix it. Anyway, adjusting the clutch pedal did the trick and the car was shifting perfectly and not moving when getting in to first gear and so on - basically, perfect. Also the engagement point was about 1,5 inches off the floor. Well, without changing anything the clutch is back to it's old state (after pedal being adjusted so I got just a bit of the screw left) and it's nudging a bit when shifting to first at a stop - again. So basically my engagement point changed back to where it was when we installed the clutch just in a few days of adjusting the clutch pedal. I had the same issue with the previous clutch too... I know that the clutch isn't fully disengaged if this is happening and that I'm basically destroying it if I don't get this fixed fast. Any idea what else I can do?
Things tried: adjusted pedal, bled the lines, new TOB.
Old Aug 22, 2008 | 07:58 PM
Wicked E's Avatar
Restrictor pill removed in clutch line?
-E
Old Aug 22, 2008 | 08:58 PM
Mellon Racing's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=347028
Old Aug 23, 2008 | 04:29 AM
Toxin's Avatar
Yea Chris I read your thread a while ago, but this is a new clutch
Old Aug 23, 2008 | 04:35 AM
Toxin's Avatar
-E
No I don't think so - what exactly is the "restrictor pill"? I'm not an american and sometimes the terminology of car parts takes a while to figure out what is what
Actually I'll do a search on it, thanks for the input!
Old Aug 23, 2008 | 04:43 AM
Ev0cRaZy's Avatar
I had the same issue with my Twin Disc, worn out within 10k, so I went back with the ACT.
Old Aug 23, 2008 | 05:10 AM
Toxin's Avatar
The point is that more than not people have proven that the Twin HD is a very worthwhile clutch to have, especially because of the rebuildability for 1/3 the price. I just bought mine and I'd like to get it to work properly until I reach 35093 whp which I doubt will happen on my daily driver. After all the reviews I opted for the twin disc in order to have it and rebuild it whenever needed. A clutch job in Slovenia I can get done for 250-300$. And if I get 10k on the discs and have to replace them every 10k I'm fine with that. I do about 20k per year. I launch my car let's say once per week on average with occasional drag race days. Launched this twin only once so far and I loved the way I could do that, it's just annoying with the issues I have for normal driving.
Edit: spelling
Old Aug 23, 2008 | 06:39 AM
Ev0cRaZy's Avatar
Edit: spelling
Ok so what are you trying to tell me here? I simply gave you MY experience, I didnt need you to post a novel of "your point" which made 0 sense to me
Old Aug 23, 2008 | 06:57 AM
Toxin's Avatar
Yea... I'll make it more understandable to you: I do not wish to go to ACT, I wish to make my Exedy to work properly. Thank you for sharing your experience though.
Old Aug 23, 2008 | 06:58 AM
1NastyMR's Avatar
Should of just rebuilt your twin disk
Old Aug 23, 2008 | 09:14 AM
pretty odd for a new clutch unless you somehow managed to burn it up on a launch
Old Aug 23, 2008 | 09:22 AM
4WS Tuning's Avatar
Sounds like air in the line... Try bleeding the clutch Ales.
Cheers!
Old Aug 23, 2008 | 09:58 AM
rawkus's Avatar
It could also be a bad slave or master cylinder. Check to see if it is leaking any fluid around the clutch pedal where it adjusts and also the slave on the front of the transmission case.
Dan
Old Aug 23, 2008 | 07:38 PM
Toxin's Avatar
Thanks for all the advice everyone, I'll be putting it on the lift tomorrow and we'll see what we can accomplish!
Old Aug 28, 2008 | 11:55 AM
Toxin's Avatar
Cheers!
U're a darling Tamer! We bled it. Shifts like a charm! Thanks to everyone for chiming in! Now that we've set it up properly, I understand why everyone uses an Exedy! It's beautiful!
