NY/NJ/CT...I need help ASAP
Old Aug 26, 2003 | 12:01 PM
spoolinEVO8's Avatar
I received a call from my local mitsu dealership that the Twin Plate Exedy Clutch I dropped off needs a special tool to line up the twin plates before they can install this.
Is this true? And if so, where is the closest that I can find a tool like this?
Please help me. Thanks.
Ken
Old Aug 26, 2003 | 12:04 PM
Alfriedesq's Avatar
You need a spare out put shaft from a evo - I am suprized that they do not have the pilot tool to do it
You could always bring your car to Pruven - they have the tools
Old Aug 26, 2003 | 12:05 PM
zlancer's Avatar
i'm guessing the clutch should have came with the alighment tool.....check the box....if not u might have to order it??
Old Aug 26, 2003 | 12:08 PM
Al: I would love to bring the car to Pruven, but my car is in pieces right now @ White Plains Mitsu. Its been there for a month and a week already.
zlancer: I dont think I remember seeing any pilot tool in the box. Its really pissin me off now. My car has been @ mitsu longer than I have had it....lol
Ken
Old Aug 26, 2003 | 12:10 PM
btw, what exactly is this pilot tool? Is that the output shaft from another EVO?
I dont know what to tell them.
Ken
Old Aug 26, 2003 | 12:38 PM
Noize's Avatar
EvoM Administrator
This stuff sucks. Good luck, Ken!
Old Aug 26, 2003 | 12:55 PM
HobieKopek's Avatar
I'm amazed the clutch didn't come with it. Did you try calling Daikin Clutch or the store you bought it from to see if they could send/sell you one? Perhaps it should have been included?
Old Aug 26, 2003 | 12:59 PM
N10S's Avatar
A pilot tool is basically a black nylon tool that has the same spline/shaft configuration of the stock tranny input shaft. The tool slips through the female splines of the clutch disc(s) aligning them as you insert the tool. The very end of the tool slips into the pilot bearing(see end of crank)and once in place provides proper clutch plate indexing. Once indexed the pilot tool is removed and then the clutch plates and pilot bearing are aligned and ready for the tranny input shaft to be installed.
I wouldn't think the twin disc unit would require a special pilot tool, but maybe? Perhaps they just don't have a pilot tool for the Evo ?
Good luck in your quest to find one, I wouldn't think it would be too tough. BTW- these tools are typically about $10-25
N10S
Old Aug 26, 2003 | 01:46 PM
the service manager mentioned that since it is a twin plate, it would need a special alignment tool.
The tech that was working on my car previously mentioned that regardless, clutch work on an evo required a special tool, but he quit yesterday...lol
So now, I have the manager calling me today, telling me the new tech says that it needs something special for the twin plate.
Needless to say, Im confused.
Does anyone with experience in the install of a twin plate clutch know if a special tool is needed for the TWIN PLATE install? Or is it the same tool that is needed with any clutch install on the EVO?
Ken
Old Aug 26, 2003 | 04:25 PM
RaX's Avatar
RaX
In this thread Adam from Z1 Performance states:
The Exedy Hyper and Dual disk clutches do not come with alignment tools or throw out bearings - only their less expensive clutches do (aka their Sport Line, though they don't even offer these for the Evo!)....it never made sense to me either and I have made the request they change it many many times already
So maybe try asking him where to get the tool.
Old Aug 26, 2003 | 07:35 PM
JP importz's Avatar
This thing doesn't make sense when you buy an aftermarket clutch it always come with the alignment tool. I will find out when i replace my clutch in about .........uhhhhhhhhhhhhh.....3 months.
Old Aug 26, 2003 | 07:49 PM
Alfriedesq's Avatar
Ken
I'll be happy to come down and allign your clutch for those idiots if you want - just clear it with them - it will take me 5 mins
PS - make sure they put your clutch in the right way - its balanced as a unit - and CLEAN it !
Old Aug 26, 2003 | 07:51 PM
Alfriedesq's Avatar
All you need is a tranny input shaft - you slip it through the two disks - - then you eye ball it to get it right in the ceneter - - (there is no stub that goes into the flywheel)- - when its dead center you start to tighten the screws - 5 min job
Old Aug 26, 2003 | 09:21 PM
Hey Al, Im going to IM you.
Ken
Old Aug 27, 2003 | 10:52 AM
Can anyone in the area possibly let me borrow, or @ worst, buy the tool from you if you have it? My car is @ the dealer now, and now they are charging me storage because my car is taking up a bay.
Please post here, or IM me @ spoolinGTI on aim.
Thanks
Ken
